Graphic visualization for EQs
Hi @zynthianers!
I’ve implemented a visualization widget for the GxGraphicEQ, a graphic 11 band EQ that is enabled by default in zynthian. It works like this:
Note that you can also use the touch to adjust the EQ band gains.
In the next days/weeks, i would like to implement, at least another EQ visualization widget, this time for a parametric EQ. I really like the x42-eq, but i’m open to other proposals. What is your favorite parametric EQ in zynthian?
All the best!
That sounds fantastic! Can you tell how zynthian UI will sort out the internal parameter conversions for normalized parameters and underlying parameters (like filter orders)?
For plugins exposing real values it seems to be easier, given the engine is clear about the bandwidth/Q thing.
Just to answer your question. I would vote also for x42 equalizer, I use it where I can (Zynthian, DAW, …).
I’d like to mention the possibilities with the built-in spectrum analyzer, which helps really a lot. Unfortunately only with VNC enabled.
