Hi, I just noticed that If I want to change the pianoteq preset of an instrument, it’s no longer possible (since one week or so) to just scroll through the preset list and press select (the heading changes but the preset remains the same as before). So I have to completely remove the layer and start all over again, i.e. from the menu, chose “new synth layer” → “Pianoteq 7.2 STANDARD” → “MIDI Ch#1” and so on.
The option “[ ] Preset Preload” has no effect on that.
My system:
zyncoder: master (3c914fe)
zynthian-ui: master (84a7f25)
zynthian-sys: master (348f40c)
zynthian-data: master (194fd59)
zynthian-webconf: master (c8cd1a6)
Yeah, you are right! The GUI shows something trying to change but it doesn’t. You should report this as a bug in the issue tracker.
The LV2 version works okay if you want to use that as a temporary work around (although the presets will be in a different order to what you may be expecting).
Thank you for confirming the observed behaviour. I submitted the issue as proposed.
OK! It looks like i’ve been sabotaging my own code with the latest commits … jejeje!
It may be fixed now. Simply update and test.
