Hi, having a fun time with Zynthian, as there are so many high quality engines on board. Loads of amazing samples too, and I added my own EMU Soundfonts. A couple of small niggles exist though.
- Calf Wavetable seems to have no way of actually sweeping the wavetables…there’s a manual control to let you do it, but the onboard UI envelopes do nothing, and the VNC web interface brings up an error message whenever I try to assign an LFO or envelope in the bottom section of the Calf Wavetable VNC UI screen. Could someone try this for me and see if they get the same issue?
- Odin 2 has many parameters available in the onboard UI, but not what’s probably most essential - the ability to change osc type (from analogue to wavetable to Phase mod etc) - I don’t suppose this could be implemented - maybe you’re at the mercy of what parameters the LV2 makes available? The web interface is very nice so it’s not the biggest issue.
- I see Osiris available in the LV2 list so I activated it, but it currently doesn’t load up (I think a ROM may be missing) any clues on how to load that up?
Thanks for everything so far, it’s a real fun synth! I’ll post demos at some point ![]()
