HDMI Audio causing a reboot loop?
Sorry @ReCremisi89 !
I never got HDMI audio working reliably. Perhaps some other user could help you on this, if any.
Absolutely, but having HDMI audio working is a step ahead of the issue:
If i set these jackd flags in the audio webconf
-P 70 -t 2000 -s -d alsa -d hdmi:vc4hdmi0 -r 48000 -o 2 -p 512 -n 2 -X raw
after saving and rebooting i get these
-P 70 -t 2000 -s -d alsa -d hw:vc4hdmi0 -r 48000 -o 2 -p 512 -n 2 -X raw
notice that the -d hdmi flag is changed to -d hw, and prevents the UI from starting.
OK! Please update (vangelis) and test again.
Thanks for the fix, however no luck so far…
I switched to vangelis branch, updated and rebooted.
With Soundcard “Custom Device” and Driver Config “dtparam=audio=on
dtoverlay=vc4-kms-v3d”, if i set this string in jackd fields:
-P 70 -s -S -d alsa -d hdmi:vc4hdmi0 -r 48000 -p 256 -n 2 -o 2 -X raw
after clicking “save” I get this
-P 70 -s -S -d alsa -d hw:i:vc4hdmi0 -r 48000 -p 256 -n 2 -o 2 -X raw
FYI, If i manually set the jackd flags
jackd -P 70 -t 2000 -s -d alsa -d hdmi:vc4hdmi0 -r 48000 -o 2 -p 512 -n 2 -X raw
via an ssh cli in an RPI4, the UI starts, and use the Admin/Test Audio function, I get sound.
This is a step forward, and i want to try also on the RPI5.
I’ll do more tests in the meantime…
