Hi Guys,
I came across with a strange problem. I am using test image with my pi5 (rel. 22-5), Booting from SD card and NVME works ok-ish. Encoders connected to GPIO (i carefully avoided all pins used by HifiBerry), All works, however if I update the Zynthian (either through WebConf or via Admin page on the LCD) HifiBerry no longer works, shows Error - MIDI/Audio. When I change the audio to DUMMY it loads. Aplay -l shows the HifiBerry, LED is ON. When I set the audio to HifiBerry DAC+, Zynth keeps restarting showing the error and Aplay -l no longer shows the HifiBerry. LED is ON. I tried to set Wiring to Dummies to see if Encoders might be a problem. No luck. ORAM without update works - After update does not work.
