i am trying to use the Digi+ I/O Board with Zynthian. I am using a motu Ultralite AVB with optical in and out.
I am using the mouti in mixer mode with my eurorack stuff and wanted to use the zynthian first as a effekt device…
I thought with the digital io i got more analog ports free.
I only tested MOD-Host
Output is working but i got no Input. Bitrate ist set to 48000 with the mixer runs at.
I can record from the optical input with arecord:
arecord --device=hw:CARD=sndrpihifiberry,DEV=0 -r 48000 -f S16_LE -c 2 -d 5 /root/test2.wav
root@zynthian:~# arecord -L
null
Discard all samples (playback) or generate zero samples (capture)
default:CARD=sndrpihifiberry
snd_rpi_hifiberry_digi, HifiBerry Digi HiFi wm8804-spdif-0
Default Audio Device
sysdefault:CARD=sndrpihifiberry
iec958:CARD=sndrpihifiberry,DEV=0
IEC958 (S/PDIF) Digital Audio Output
dsnoop:CARD=sndrpihifiberry,DEV=0
Direct sample snooping device
Direct hardware device without any conversions
plughw:CARD=sndrpihifiberry,DEV=0
Hardware device with all software conversions
Did anyone using this card? It would be cool to use a digital io path for a digital maschine. I am even thinking if ADAT protocoll is possible to get mot ins and outs.
Regards Jens
