I’m trying to work out a way when playing live of holding or latching a note to create a “drone pad” on a layer which continues behind everything else played on another layer.
So I am in Stage mode, the idea is I would switch to the pad layer, hit the note I want on the keyboard and that note would then latch on. Then I switch to a piano layer to play piano over the top of that. (I’ll have the pad layer volume mapped to a controller or something to fade it out at the end)
I thought maybe if I manually set Sustain “on” for the pad layer, that might work, but as soon as I hit the sustain pedal on the piano layer, it also changes the sustain on the pad layer.
Can anyone help me achieve this?
