Hi all,
I have a issue with this audio card:
It is not detected on startup, but it becomes available after replugging.
I can rule out an issue with the Raspberry and the Audio card, as they work with modep. Also no issue with zynthiam oram whenever I use other audio cards (UMC204HD and Revelatori IO 44).
I submitted an issue [Issue: HOTONE Jogg Audio Card not detected on startup. · Issue #1237 · zynthian/zynthian-issue-tracking · GitHub](https://HOTONE Jogg Audio Card not detected on startup.)
@chrisp250 I know that you have the same device and use it with zynthian, may I kindly ask you if you updated to Oram and experienced the same.
Many thanks in advance for any help provided, very close to a usable setup that i want to post in the success cases.
Have all a nice weekend!
