If no, try clicking into that listing and there should be another option to turn the driver on (if it has been turned off for some reason). I believe it should turn on by default though so not sure why that would happen.
Another general troubleshooting could be to plug another device (if you have one) that has a driver available and see if it works.
Yes! Thanks for this… I saw the MPK’s entry in the menu and assumed that it had been recognised, so didn’t take this any further. It works a treat now.
One other question: I have to manually re-load the driver on each boot up… is there a way that I can have it default to loading automatically. Thanks again!
