Thanx, Fernando, and yes, I know that.
My dream is to configure my whole equipment with one progchange-command to the snapshots. What I miss is the possibility to call one audio-file in one snapshot. Than I don’t have to push a lot of knobs between the songs.
Difficult to manage. Currently snapshots doesn’t include anything related to captures.
The “captures” system of zynthian is only a quick & dirty patch that has grow up a little bit, but it will be replaced/improved for something cooler … more DAWish
Anyway, i will think about your use-case … if i understand correctly, you would like to auto-play a given capture when you load the snapshot, right?
Permissions can often be the cause of problems with PSFTP, read the error messages carefully, especially which end of the relationship is having problems.
Might be a rather old thread, but from PuTTY I understand a Windows OS is used.
I miss the hint to winscp in this case, which could ease up file transfers via ssh a lot:
For a few years (at least since Windows 10) MS Windows supports ssh from the command line. You can ssh and scp from within a Windows command prompt. I do this often when forced to use Windows.
