Hi folks,
In the default ZynPad view, the last column has channel 10. Is it possible to change the default channel to 11? And another question, how can I change the channel for the entire column and not just one pad? I can’t find the option, if it’s even possible to do that.
Hi @nucklear.
Please check the docs on the wiki which are pretty good.
You can’t chage the default MIDI channel nor can you change a whole column in one go but you can change the actual MIDI channel for each pad. Select the pad you want to change the press the OPT button (V5) or the LAYER knob on V4. This will show a menu including “MIDI Channel”. Select this then select the desired channel.
Who wrote those then…?
