How to confirm my new build (encoders)?
Greetings All
New 4.1 build here (Warning - Zynthian noob). Should rotating “select” scroll through lists on the screen (for example - in the Main screen)? I have also noticed that pressing the select button doesn’t do anything… is there a log somewhere on the filesystem that I can tail to check if the encoders are being properly read
Try swappimg the encoders to confirm if some if them is broken. Did you force the encoders while mounting them, specially when inserting the knobs?
Cheers
Yes, I had to press quite hard. I will order a set of encoders and try again…
Try swapping the encoders to see if they are broken, how many are broken, etc.
Plugged in a USB keyboard, so at least I can navigate at the moment… and yes, looks like at least two are damaged
If you have a multimeter with a continuity buzz option, connect it across the two outer connectors and turn the encoder. You should here it click as the two phases of the encoder overlap…
Did you swap it? Please, try swapping encoders and also cables. Check all combinations carefully …
Also sometimes colors aren’t in the same order, but still work fine. look at the plug and connector. The pins and holes are off center so make sure they match up or you may mash them.
yes, and some of the encoders are not working. New ones ordered yesterday …
