How to fix MIDI velocity to 127 [solved]
How can i set MIDI velocity to 127 to use for pipe organs or cembalos?
Hi @piattica - I’m not sure what you’re asking for - Aeolus is one of the pipe organ oriented synths on default Zynthian, and I think it ignores midi velocity anyway. Perhaps you can explain a bit more about what you are trying to do.
A search on ā€œaeolusā€ will also get you quite a lot of related discussion about how Aeolus works.
Here’s the thread where Aeolus started on Zynthian, note that this is historical, now it is just there in Zynthian:
thank you for the quick answer.
I am looking for a solution to use sf2 pipe organs
You can try add MIDI-FX in Chain Options.
Look on ā€˜MIDI Velocity Adjust’ or ā€˜MIDI Velocity Gamma’ from LV2-Plugins. You must first actrivate it in webconf http://zynthian.local/sw-jalv-lv2
thank you ToFF, solved
That’s got to be worth an addition to the collection!
