How do I load sfz files for Sfizz? The sfz comprises a sfz file and a series of samples, and it seems that I have to load them in compressed form. That’s easy to do, but should they all be in a directory first? Should the be subdirectories? All the samples should be .wav files??
To date I’ve only loaded sf2 files for FluidSynth and that is pretty straight forward.
You have to prepare a zip containing a folder. Inside this folder you have to put all the files, samples and sfzs. I recommend creating a subfolder for the samples and putting the sfz in the top level. You can put more than one sfz (instrument) in each bundle.
I was actually after the format of where to put the .wav files relative to the .sfz, but your comments have been helpful. I haven’t been able to see any of the files on the USB stick I tried previously, and I figured I was looking in the wrong place on the Zynth, but it turns out the stick was NTFS. I tried a FAT one and it works. So thanks for that.
