When you save a ZS3 snapshot you do it under a Program Change number.
You need to send MIDI Program Change commands from the MIDI conttroller and you’ll be done.
Yes, it’s probably slower than a ZS3 change but I need the Chaannel changes.
In the userguide it says “It is possible to recall snapshots via MIDI Program Change. New snapshots are assigned the next available MIDI Program Change”.
and in the Snapshot page you can set a program (I asume a Midi Program Change) number.
There’s a new version coming soon that unbinds MIDI channels from what in zynthian are called chains, now a MIDI channel is linked to an engine.
Until now I’ve been able to use ZS3 snapshots for live performances, Program Change is super fast and you can change the engine preset every time. The only limitation is that you need to load all your engines in the snapshot. IMHO there’s no need to use snapshots unless you have a completely different set of engines
Anyway, maybe someone that knows better than I do can answer
I can confirm that the documentation does state that snapshots can be recalled by program change and that this does not seem to work in any scenarios / configurations I have tried.
Progam Change operates differently depending on the mode of the device, e.g. recalling the ZS3 or the engine’s native preset. I can imagine that the behaviour described in this part of the docs may be intended for master channel but it does not work.
@jofemodo could you explain what the intended behaviour is? (I have been working on program change behaviour recently so this question is timely.)
Thanks Pau, your method using ZS3’s is understood en working.
@jofemodo
Due to the fact changing Snapshots via Midi Program Change Commands seems interesting (at least for me) and in the current implementation Midi Program Changes are used to select ZS3’s maybe the masterchannel could be used. So Midi Program Change commands in the masterchannel are used for Snapshot selection and Midi Program Changes on the other 15 channels are used for selection of ZS3’s.
This only works after the snapshot page has been accessed once. If you start Zynthian up fresh and send program change on master channel then the snapshot is not loaded.
