Frustrating… as I keep getting into learn mode as if by default. In my case the mixer page (for my soundcard pcm out) keeps getting assigned.
A reboot clears it, but it is as if the UI learns all the time.
It needs a switch in webconf so that learning is OFF by default. I’d prefer a spreadsheet styled interface to allow Channel/Controller mapping to be routed to layer parameters per synth, effect etc.
BTW are there any predefined assignments for each instrument/FX when you add them to Zynthian? Should there be a list of these?
Are you using a touchscreen? It is too easy to enter learning mode from the touchscreen interface. If this is your issue the try raising a feature request to change behaviour.
Yes a Waveshare USB/HDMI 7-inch (Why not metric? Are parts of China still Imperial?). It’s currently mounted to the top of my previous Zynth (Pi-3) case whilst connected to the Pi-4 I am testing (it has a cooling fan https://shop.pimoroni.com/products/fan-shim running without driver) which precludes the use of the old case, a dead D-link router - the search for a new home has begun!
