@gilrain confirmed it worked for him. I will check again.
It worked for me on test last week. I didât try since then.
@jofemodo here is the MIDI options section⌠I importetd it with the backup import function. Maybe something happened there?
Thank you for investigating this.
It works sometimes, not always⌠I can assingn a parameter to midi, itâs OK. But it only works when I have the web interface connected. If I disconnect, it stops working. After a reboot, if I start web interface first, it works. But if I try the controller before start web interface, it moves a little, but almost immediatly stops, and doesnât work anymore.
It seems that the midi learning works, but the operation of the assigned controller somehow depends on the connection between Zynthian and the web interface.
âŚwhich basically means, that it doesnât work. I just did an update and I cantât even see the parameters of the MOD-UI panels (as in the pic above). So I will go back to staging 2210, i guess. That did work fine. And as I probably donât need the other functonalities that might come⌠wish I wouldnât have toâŚ
This is the best workaround. Iâm afraid that the Zynthian MOD-UI development is not a priority at the moment. I like the new UI with the mixer, itâs very good for the synth side, but not for the guitar side. I canât control MOD-UI pedalboards with my midi footswitchâŚ
I havenât seen a bug repot in the issue tracker for this. We need unambiguous and detailed bug reports to be able to investigate issues. I think there are two different issue discussed in this forum:
It was about the midi learn, the empty control view is another issue, and I didnât have it on testing.
Last time I tried two weeks ago midi learn worked when MOD web interface was active, otherwise not. I will test again tonight.
The same thing is happening as two weeks ago.
All repos on testing branch, updated before test.
This is also the same as three weeks ago:
