I just accidentally broke the one connection that controls everything.
Should have used an optical TOS-link
How’s the screen?
Hello, there may be a way to do something by welding
That’s why I always attach an extra usb b for durability. The problem is not usb, is micro/mini usb.
I bought a Novation MIDI Controler Keyboard on Craigslist for $15, the owner had torn out the USB connector and botched the replacement. Jumper wires and a bit if glue got it functioning.
While OK on the outside, everything on the inside is extra cheap, the baklite PCB was behind the connector failure, the keyboard uses no hinges or springs, just bendy plastic.
