The first handmade synthesizer in my life.
Sound card:PCM5122+1863
Zynaptic:74HC14+MCP23017,74HC14 can make encoder signal more stable.
Screen: MIPI
Power:buck module convert 12v to5v for raspberry ,7805 for soundcard (I think a common mode choke is necessary to use.)
PreAMP: Using JRC4580 OP amp to amplify moving coil MIC signal and the other one to amplify the signal from DAC to Headphone.
At present ,the most serious problem is temperature .Because of the small case,temperature always rise to 70 C when power on for 30 minutes.I want to use sheet copper to dissipate heat in next step.
