PRI 4 has 2 micro HDMI connectors. I want to use HDMI #2 out as the default. But currently default is HDMI #1.
Anyone can help with an advise on how to switch those around?
Thank you!
Michael
Thank you!
Michael
Hi @sinitsinmike , good question.
For sure this should be doable.
But right now I have no idea and no gear under my hands To test this.
Found the way, and it works:
Just be aware the web config rewrites the config.txt file so it will revert depending on various things.
