Hi experts…
OK I have the Zynthian and yes I have RTFM but I’m not as young as I used to be and following the flow charts is still causing me a little grief…
I have connected to the Web configuration too and that’s working Ok. What I need is an idiot guide to setting up several synth engines with the associated midi channels and have the same setup each time I switch the unit on. Yes I know you’ll tell me it’s simple but I seem to have a mental block at this point. I will read the manual again but I’m sure someone can give me an example work flow… please ?
Thanks so much for any help… cheers Phil
In the webconfig go to Library -> Snapshots and if there is a “default” snapshot then delete it.
Create an all singing all dancing multi-layer snapshot and save it.
Back in the web config, find your snapshot layer, scroll to the bottom and save it as default.
Reboot the zynth to test.
Thanks I’ll try that today
Can the midi channels be changed from the web config ?
The what what of the what?
