And second test was:
Raspberry Pi 400 Rev 1.1
Audio: PiSound
Display: Generic HDMI Display
Wiring: DUMMIES
-- Logs begin at Thu 2019-02-14 10:11:58 GMT. --
Aug 15 17:54:57 zynthian systemd[1]: Started Zynthian User Interface (DEBUG).
Aug 15 17:54:57 zynthian startx[2192]: X.Org X Server 1.20.4
Aug 15 17:54:57 zynthian startx[2192]: X Protocol Version 11, Revision 0
Aug 15 17:54:57 zynthian startx[2192]: Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian
Aug 15 17:54:57 zynthian startx[2192]: Current Operating System: Linux zynthian 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
Aug 15 17:54:57 zynthian startx[2192]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=720 bcm2708_fb.fbheight=576 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:A7:D1:CE vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.speed=1 dwc_otg.lpm_enable=0 console=tty3 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait logo.nologo quiet splash
Aug 15 17:54:57 zynthian startx[2192]: Build Date: 04 August 2022 12:56:42PM
Aug 15 17:54:57 zynthian startx[2192]: xorg-server 2:1.20.4-1+rpt4+deb10u5 (https://www.debian.org/support)
Aug 15 17:54:57 zynthian startx[2192]: Current version of pixman: 0.36.0
Aug 15 17:54:57 zynthian startx[2192]: Before reporting problems, check http://wiki.x.org
Aug 15 17:54:57 zynthian startx[2192]: to make sure that you have the latest version.
Aug 15 17:54:57 zynthian startx[2192]: Markers: (--) probed, (**) from config file, (==) default setting,
Aug 15 17:54:57 zynthian startx[2192]: (++) from command line, (!!) notice, (II) informational,
Aug 15 17:54:57 zynthian startx[2192]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Aug 15 17:54:57 zynthian startx[2192]: (==) Log file: "/var/log/Xorg.0.log", Time: Mon Aug 15 17:54:57 2022
Aug 15 17:54:57 zynthian startx[2192]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Aug 15 17:54:57 zynthian startx[2192]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Aug 15 17:54:58 zynthian startx[2192]: /zynthian/config/img/fb_zynthian_boot.png is 720x576 PNG image, color type GRAY, 8 bit
Aug 15 17:54:58 zynthian startx[2192]: Zooming image by 100%...done
Aug 15 17:54:58 zynthian startx[2192]: Merging...didn't find evidence of prior run.
Aug 15 17:54:58 zynthian startx[2192]: done
Aug 15 17:54:58 zynthian startx[2192]: Building XImage...done
Aug 15 17:54:59 zynthian startx[2192]: INFO:zynthian_gui_config.<module>: ZYNTHIAN-UI CONFIG ...
Aug 15 17:54:59 zynthian startx[2192]: INFO:zynthian_gui_config.<module>: No Wiring Layout configured. Only touch interface is available.
Aug 15 17:54:59 zynthian systemd[1]: Stopping Zynthian User Interface (DEBUG)...
Aug 15 17:54:59 zynthian startx[2192]: Cannot connect to server socket err = No such file or directory
Aug 15 17:54:59 zynthian startx[2192]: Cannot connect to server request channel
Aug 15 17:54:59 zynthian startx[2192]: jackdmp 1.9.14
Aug 15 17:54:59 zynthian startx[2192]: Copyright 2001-2005 Paul Davis and others.
Aug 15 17:54:59 zynthian startx[2192]: Copyright 2004-2016 Grame.
Aug 15 17:54:59 zynthian startx[2192]: Copyright 2016-2019 Filipe Coelho.
Aug 15 17:54:59 zynthian startx[2192]: jackdmp comes with ABSOLUTELY NO WARRANTY
Aug 15 17:54:59 zynthian startx[2192]: This is free software, and you are welcome to redistribute it
Aug 15 17:54:59 zynthian startx[2192]: under certain conditions; see the file COPYING for details
Aug 15 17:54:59 zynthian startx[2192]: JACK server starting in realtime mode with priority 10
Aug 15 17:54:59 zynthian startx[2192]: self-connect-mode is "Don't restrict self connect requests"
Aug 15 17:55:00 zynthian startx[2192]: creating alsa driver ... hw:0|hw:0|1024|2|48000|0|0|nomon|swmeter|-|32bit
Aug 15 17:55:00 zynthian startx[2192]: ALSA: Cannot open PCM device alsa_pcm for capture. Falling back to playback-only mode
Aug 15 17:55:00 zynthian startx[2192]: configuring for 48000Hz, period = 1024 frames (21.3 ms), buffer = 2 periods
Aug 15 17:55:00 zynthian startx[2192]: ALSA: final selected sample format for playback: 16bit little-endian
Aug 15 17:55:00 zynthian startx[2192]: ALSA: use 2 periods for playback
Aug 15 17:55:00 zynthian startx[2192]: DEBUG:zynthian_config.get_disabled_midi_in_ports: DISABLED_MIDI_IN = ['']
Aug 15 17:55:00 zynthian startx[2192]: DEBUG:zynthian_config.get_enabled_midi_out_ports: ENABLED_MIDI_OUT = ['ttymidi:MIDI_out']
Aug 15 17:55:00 zynthian startx[2192]: DEBUG:zynthian_config.get_enabled_midi_fb_ports: ENABLED_MIDI_FB = ['Arturia_BeatStep_Pro_MIDI_1']
Aug 15 17:55:00 zynthian startx[2192]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
Aug 15 17:55:00 zynthian startx[2192]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
Aug 15 17:55:00 zynthian startx[2192]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
Aug 15 17:55:00 zynthian startx[2192]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
Aug 15 17:55:00 zynthian startx[2192]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
Aug 15 17:55:01 zynthian startx[2192]: libzynmixer: Registering as 'zynmixer'.
Aug 15 17:55:01 zynthian startx[2192]: libzynmixer: Created input ports
Aug 15 17:55:01 zynthian startx[2192]: libzynmixer: Registered output ports
Aug 15 17:55:01 zynthian startx[2192]: libzynmixer: Activated client
Aug 15 17:55:02 zynthian startx[2192]: INFO:zynthian_gui.<module>: STARTING ZYNTHIAN-UI ...
Aug 15 17:55:02 zynthian startx[2192]: INFO:zynthian_gui_keybinding.load: Loading key binding from keybinding.yaml
Aug 15 17:55:02 zynthian startx[2192]: DEBUG:zynthian_gui_keybinding.load: Loading default keyboard bindings.
Aug 15 17:55:02 zynthian startx[2192]: INFO:zynthian_gui.zynswitches_init: INIT 0 ZYNSWITCHES ...
Aug 15 17:55:02 zynthian startx[2192]: INFO:zynthian_gui.zynswitches_midi_setup: CUSTOM I/O SETUP...
Aug 15 17:55:02 zynthian startx[2192]: DEBUG:zynthian_engine_mixer.get_controllers_dict: MIXER CTRL LIST: ['']
Aug 15 17:55:02 zynthian startx[2192]: Invalid card number.
Aug 15 17:55:02 zynthian startx[2192]: ERROR:zynthian_engine_mixer.get_mixer_zctrls: Command 'amixer -M -c pisound' returned non-zero exit status 1.
Aug 15 17:55:03 zynthian startx[2192]: INFO:zynthian_gui_midi_recorder.__init__: midi recorder created
Aug 15 17:55:03 zynthian startx[2192]: INFO:zynthian_gui.osc_init: ZYNTHIAN-UI OSC server running in port 1370
Aug 15 17:55:03 zynthian startx[2192]: INFO:zynthian_gui_admin.stop_rtpmidi: STOPPING RTP-MIDI
Aug 15 17:55:03 zynthian startx[2192]: JackGraphManager::Disconnect not connected port_src = 28 port_dst = 93
Aug 15 17:55:03 zynthian startx[2192]: JackGraphManager::Disconnect not connected port_src = 28 port_dst = 95
Aug 15 17:55:04 zynthian startx[2192]: INFO:zynthian_gui_admin.stop_qmidinet: STOPPING QMIDINET
Aug 15 17:55:04 zynthian startx[2192]: INFO:zynthian_gui_admin.start_touchosc2midi: STARTING touchosc2midi
Aug 15 17:55:09 zynthian startx[2192]: xinit: connection to X server lost
Aug 15 17:55:09 zynthian startx[2192]: [1B blob data]
Aug 15 17:55:09 zynthian startx[2192]: waiting for X server to shut down Jack main caught signal 15
Aug 15 17:55:10 zynthian startx[2192]: (II) Server terminated successfully (0). Closing log file.
Aug 15 17:55:10 zynthian startx[2192]: xinit: unexpected signal 15
Aug 15 17:55:10 zynthian systemd[1]: zynthian_debug.service: Main process exited, code=exited, status=1/FAILURE
Aug 15 17:55:10 zynthian systemd[1]: zynthian_debug.service: Failed with result 'exit-code'.
Aug 15 17:55:10 zynthian systemd[1]: Stopped Zynthian User Interface (DEBUG).
Aug 15 17:55:10 zynthian systemd[1]: Started Zynthian User Interface (DEBUG).
Aug 15 17:55:10 zynthian startx[2456]: X.Org X Server 1.20.4
Aug 15 17:55:10 zynthian startx[2456]: X Protocol Version 11, Revision 0
Aug 15 17:55:10 zynthian startx[2456]: Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian
Aug 15 17:55:10 zynthian startx[2456]: Current Operating System: Linux zynthian 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
Aug 15 17:55:10 zynthian startx[2456]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=720 bcm2708_fb.fbheight=576 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:A7:D1:CE vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.speed=1 dwc_otg.lpm_enable=0 console=tty3 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait logo.nologo quiet splash
Aug 15 17:55:10 zynthian startx[2456]: Build Date: 04 August 2022 12:56:42PM
Aug 15 17:55:10 zynthian startx[2456]: xorg-server 2:1.20.4-1+rpt4+deb10u5 (https://www.debian.org/support)
Aug 15 17:55:10 zynthian startx[2456]: Current version of pixman: 0.36.0
Aug 15 17:55:10 zynthian startx[2456]: Before reporting problems, check http://wiki.x.org
Aug 15 17:55:10 zynthian startx[2456]: to make sure that you have the latest version.
Aug 15 17:55:10 zynthian startx[2456]: Markers: (--) probed, (**) from config file, (==) default setting,
Aug 15 17:55:10 zynthian startx[2456]: (++) from command line, (!!) notice, (II) informational,
Aug 15 17:55:10 zynthian startx[2456]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Aug 15 17:55:10 zynthian startx[2456]: (==) Log file: "/var/log/Xorg.0.log", Time: Mon Aug 15 17:55:10 2022
Aug 15 17:55:10 zynthian startx[2456]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Aug 15 17:55:10 zynthian startx[2456]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Aug 15 17:55:11 zynthian startx[2456]: /zynthian/config/img/fb_zynthian_boot.png is 720x576 PNG image, color type GRAY, 8 bit
Aug 15 17:55:11 zynthian startx[2456]: Zooming image by 100%...done
Aug 15 17:55:11 zynthian startx[2456]: Merging...didn't find evidence of prior run.
Aug 15 17:55:11 zynthian startx[2456]: done
Aug 15 17:55:11 zynthian startx[2456]: Building XImage...done
Aug 15 17:55:12 zynthian startx[2456]: INFO:zynthian_gui_config.<module>: ZYNTHIAN-UI CONFIG ...
Aug 15 17:55:12 zynthian startx[2456]: INFO:zynthian_gui_config.<module>: No Wiring Layout configured. Only touch interface is available.
Aug 15 17:55:12 zynthian systemd[1]: Stopping Zynthian User Interface (DEBUG)...
Aug 15 17:55:12 zynthian startx[2456]: Cannot connect to server socket err = No such file or directory
Aug 15 17:55:12 zynthian startx[2456]: Cannot connect to server request channel
Aug 15 17:55:12 zynthian startx[2456]: jackdmp 1.9.14
Aug 15 17:55:12 zynthian startx[2456]: Copyright 2001-2005 Paul Davis and others.
Aug 15 17:55:12 zynthian startx[2456]: Copyright 2004-2016 Grame.
Aug 15 17:55:12 zynthian startx[2456]: Copyright 2016-2019 Filipe Coelho.
Aug 15 17:55:12 zynthian startx[2456]: jackdmp comes with ABSOLUTELY NO WARRANTY
Aug 15 17:55:12 zynthian startx[2456]: This is free software, and you are welcome to redistribute it
Aug 15 17:55:12 zynthian startx[2456]: under certain conditions; see the file COPYING for details
Aug 15 17:55:12 zynthian startx[2456]: JACK server starting in realtime mode with priority 10
Aug 15 17:55:12 zynthian startx[2456]: self-connect-mode is "Don't restrict self connect requests"
Aug 15 17:55:13 zynthian startx[2456]: creating alsa driver ... hw:0|hw:0|1024|2|48000|0|0|nomon|swmeter|-|32bit
Aug 15 17:55:13 zynthian startx[2456]: ALSA: Cannot open PCM device alsa_pcm for capture. Falling back to playback-only mode
Aug 15 17:55:13 zynthian startx[2456]: configuring for 48000Hz, period = 1024 frames (21.3 ms), buffer = 2 periods
Aug 15 17:55:13 zynthian startx[2456]: ALSA: final selected sample format for playback: 16bit little-endian
Aug 15 17:55:13 zynthian startx[2456]: ALSA: use 2 periods for playback
Aug 15 17:55:13 zynthian startx[2456]: DEBUG:zynthian_config.get_disabled_midi_in_ports: DISABLED_MIDI_IN = ['']
Aug 15 17:55:13 zynthian startx[2456]: DEBUG:zynthian_config.get_enabled_midi_out_ports: ENABLED_MIDI_OUT = ['ttymidi:MIDI_out']
Aug 15 17:55:13 zynthian startx[2456]: DEBUG:zynthian_config.get_enabled_midi_fb_ports: ENABLED_MIDI_FB = ['Arturia_BeatStep_Pro_MIDI_1']
Aug 15 17:55:13 zynthian startx[2456]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
Aug 15 17:55:13 zynthian startx[2456]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
Aug 15 17:55:13 zynthian startx[2456]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
Aug 15 17:55:13 zynthian startx[2456]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
Aug 15 17:55:13 zynthian startx[2456]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
Aug 15 17:55:13 zynthian startx[2456]: libzynmixer: Registering as 'zynmixer'.
Aug 15 17:55:13 zynthian startx[2456]: libzynmixer: Created input ports
Aug 15 17:55:13 zynthian startx[2456]: libzynmixer: Registered output ports
Aug 15 17:55:13 zynthian startx[2456]: libzynmixer: Activated client
Aug 15 17:55:15 zynthian startx[2456]: INFO:zynthian_gui.<module>: STARTING ZYNTHIAN-UI ...
Aug 15 17:55:15 zynthian startx[2456]: INFO:zynthian_gui_keybinding.load: Loading key binding from keybinding.yaml
Aug 15 17:55:15 zynthian startx[2456]: DEBUG:zynthian_gui_keybinding.load: Loading default keyboard bindings.
Aug 15 17:55:15 zynthian startx[2456]: INFO:zynthian_gui.zynswitches_init: INIT 0 ZYNSWITCHES ...
Aug 15 17:55:15 zynthian startx[2456]: INFO:zynthian_gui.zynswitches_midi_setup: CUSTOM I/O SETUP...
Aug 15 17:55:15 zynthian startx[2456]: DEBUG:zynthian_engine_mixer.get_controllers_dict: MIXER CTRL LIST: ['']
Aug 15 17:55:15 zynthian startx[2456]: Invalid card number.
Aug 15 17:55:15 zynthian startx[2456]: ERROR:zynthian_engine_mixer.get_mixer_zctrls: Command 'amixer -M -c pisound' returned non-zero exit status 1.
Aug 15 17:55:16 zynthian startx[2456]: INFO:zynthian_gui_midi_recorder.__init__: midi recorder created
Aug 15 17:55:16 zynthian startx[2456]: INFO:zynthian_gui.osc_init: ZYNTHIAN-UI OSC server running in port 1370
Aug 15 17:55:16 zynthian startx[2456]: INFO:zynthian_gui_admin.stop_rtpmidi: STOPPING RTP-MIDI
Aug 15 17:55:16 zynthian startx[2456]: INFO:zynthian_gui_admin.stop_qmidinet: STOPPING QMIDINET
Aug 15 17:55:17 zynthian startx[2456]: INFO:zynthian_gui_admin.start_touchosc2midi: STARTING touchosc2midi
Aug 15 17:55:22 zynthian startx[2456]: xinit: connection to X server lost
Aug 15 17:55:22 zynthian startx[2456]: [1B blob data]
Aug 15 17:55:22 zynthian startx[2456]: waiting for X server to shut down Jack main caught signal 15
Aug 15 17:55:22 zynthian startx[2456]: JackEngine::XRun: client = ZynMidiRouter was not finished, state = Triggered
Aug 15 17:55:22 zynthian startx[2456]: JackEngine::XRun: client = ZynMaster was not finished, state = Triggered
Aug 15 17:55:22 zynthian startx[2456]: JackEngine::XRun: client = zynmixer was not finished, state = Triggered
Aug 15 17:55:22 zynthian startx[2456]: JackEngine::XRun: client = zynthstep was not finished, state = Triggered
Aug 15 17:55:22 zynthian startx[2456]: JackEngine::XRun: client = zynsmf was not finished, state = Triggered
Aug 15 17:55:22 zynthian startx[2456]: JackAudioDriver::ProcessGraphAsyncMaster: Process error
Aug 15 17:55:23 zynthian startx[2456]: (II) Server terminated successfully (0). Closing log file.
Aug 15 17:55:23 zynthian startx[2456]: xinit: unexpected signal 15
Aug 15 17:55:23 zynthian systemd[1]: zynthian_debug.service: Main process exited, code=exited, status=1/FAILURE
Aug 15 17:55:23 zynthian systemd[1]: zynthian_debug.service: Failed with result 'exit-code'.
Aug 15 17:55:23 zynthian systemd[1]: Stopped Zynthian User Interface (DEBUG).
Aug 15 17:55:23 zynthian systemd[1]: Started Zynthian User Interface (DEBUG).
Aug 15 17:55:23 zynthian startx[2705]: X.Org X Server 1.20.4
Aug 15 17:55:23 zynthian startx[2705]: X Protocol Version 11, Revision 0
Aug 15 17:55:23 zynthian startx[2705]: Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian
Aug 15 17:55:23 zynthian startx[2705]: Current Operating System: Linux zynthian 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
Aug 15 17:55:23 zynthian startx[2705]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=720 bcm2708_fb.fbheight=576 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:A7:D1:CE vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.speed=1 dwc_otg.lpm_enable=0 console=tty3 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait logo.nologo quiet splash
Aug 15 17:55:23 zynthian startx[2705]: Build Date: 04 August 2022 12:56:42PM
Aug 15 17:55:23 zynthian startx[2705]: xorg-server 2:1.20.4-1+rpt4+deb10u5 (https://www.debian.org/support)
Aug 15 17:55:23 zynthian startx[2705]: Current version of pixman: 0.36.0
Aug 15 17:55:23 zynthian startx[2705]: Before reporting problems, check http://wiki.x.org
Aug 15 17:55:23 zynthian startx[2705]: to make sure that you have the latest version.
Aug 15 17:55:23 zynthian startx[2705]: Markers: (--) probed, (**) from config file, (==) default setting,
Aug 15 17:55:23 zynthian startx[2705]: (++) from command line, (!!) notice, (II) informational,
Aug 15 17:55:23 zynthian startx[2705]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Aug 15 17:55:23 zynthian startx[2705]: (==) Log file: "/var/log/Xorg.0.log", Time: Mon Aug 15 17:55:23 2022
Aug 15 17:55:23 zynthian startx[2705]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Aug 15 17:55:23 zynthian startx[2705]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Aug 15 17:55:24 zynthian startx[2705]: /zynthian/config/img/fb_zynthian_boot.png is 720x576 PNG image, color type GRAY, 8 bit
Aug 15 17:55:24 zynthian startx[2705]: Zooming image by 100%...done
Aug 15 17:55:24 zynthian startx[2705]: Merging...didn't find evidence of prior run.
Aug 15 17:55:24 zynthian startx[2705]: done
Aug 15 17:55:24 zynthian startx[2705]: Building XImage...done
Aug 15 17:55:25 zynthian startx[2705]: INFO:zynthian_gui_config.<module>: ZYNTHIAN-UI CONFIG ...
Aug 15 17:55:25 zynthian startx[2705]: INFO:zynthian_gui_config.<module>: No Wiring Layout configured. Only touch interface is available.
Aug 15 17:55:25 zynthian startx[2705]: Cannot connect to server socket err = No such file or directory
Aug 15 17:55:25 zynthian startx[2705]: Cannot connect to server request channel
Aug 15 17:55:25 zynthian systemd[1]: Stopping Zynthian User Interface (DEBUG)...
