Hello to all,
today I play with Raspberry PI 400 as Zynthian from Scratch.
First issue was with no ethernet connection on sd card with last stable version of Zynthian 2109, so I cant make web config. (Other sd card with PatchBox Os was working on the same PI 400, vnc connection without problems). So I reconect all thing to other Raspberry PI 4 and install all without problems, swith to test version, updated and make some noise with Arturia BeatPro.
Next step was all connect back with PI 400 and input sd card with updated Zynthian. And now was running with errors, but web config is running so I have this log:
Aug 13 18:48:43 zynthian startx[8314]: INFO:zynthian_gui_config.<module>: ZYNTHIAN-UI CONFIG ...
Aug 13 18:48:43 zynthian startx[8314]: INFO:zynthian_gui_config.<module>: No Wiring Layout configured. Only touch interface is available.
Aug 13 18:48:43 zynthian startx[8314]: xinit: connection to X server lost
Aug 13 18:48:43 zynthian startx[8314]: [1B blob data]
Aug 13 18:48:43 zynthian startx[8314]: waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
Aug 13 18:48:44 zynthian startx[8314]: xinit: unexpected signal 15
Aug 13 18:48:44 zynthian systemd[1]: zynthian_debug.service: Main process exited, code=exited, status=1/FAILURE
Aug 13 18:48:44 zynthian systemd[1]: zynthian_debug.service: Failed with result 'exit-code'.
Aug 13 18:48:44 zynthian systemd[1]: Stopped Zynthian User Interface (DEBUG).
Aug 13 18:48:44 zynthian systemd[1]: Started Zynthian User Interface (DEBUG).
Aug 13 18:48:44 zynthian startx[8431]: X.Org X Server 1.20.4
Aug 13 18:48:44 zynthian startx[8431]: X Protocol Version 11, Revision 0
Aug 13 18:48:44 zynthian startx[8431]: Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian
Aug 13 18:48:44 zynthian startx[8431]: Current Operating System: Linux zynthian 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
Aug 13 18:48:44 zynthian startx[8431]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=720 bcm2708_fb.fbheight=576 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:A7:D1:CE vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.speed=1 dwc_otg.lpm_enable=0 console=tty3 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait logo.nologo quiet splash
Aug 13 18:48:44 zynthian startx[8431]: Build Date: 04 August 2022 12:56:42PM
Aug 13 18:48:44 zynthian startx[8431]: xorg-server 2:1.20.4-1+rpt4+deb10u5 (https://www.debian.org/support)
Aug 13 18:48:44 zynthian startx[8431]: Current version of pixman: 0.36.0
Aug 13 18:48:44 zynthian startx[8431]: Before reporting problems, check http://wiki.x.org
Aug 13 18:48:44 zynthian startx[8431]: to make sure that you have the latest version.
Aug 13 18:48:44 zynthian startx[8431]: Markers: (--) probed, (**) from config file, (==) default setting,
Aug 13 18:48:44 zynthian startx[8431]: (++) from command line, (!!) notice, (II) informational,
Aug 13 18:48:44 zynthian startx[8431]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Aug 13 18:48:44 zynthian startx[8431]: (==) Log file: "/var/log/Xorg.0.log", Time: Sat Aug 13 18:48:44 2022
Aug 13 18:48:44 zynthian startx[8431]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Aug 13 18:48:44 zynthian startx[8431]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Aug 13 18:48:45 zynthian startx[8431]: /zynthian/config/img/fb_zynthian_boot.png is 720x576 PNG image, color type GRAY, 8 bit
Aug 13 18:48:45 zynthian startx[8431]: Zooming image by 100%...done
Aug 13 18:48:45 zynthian startx[8431]: Merging...didn't find evidence of prior run.
Aug 13 18:48:45 zynthian startx[8431]: done
Aug 13 18:48:45 zynthian startx[8431]: Building XImage...done
Aug 13 18:48:46 zynthian startx[8431]: INFO:zynthian_gui_config.<module>: ZYNTHIAN-UI CONFIG ...
Aug 13 18:48:46 zynthian startx[8431]: INFO:zynthian_gui_config.<module>: No Wiring Layout configured. Only touch interface is available.
Aug 13 18:48:46 zynthian systemd[1]: Stopping Zynthian User Interface (DEBUG)...
Aug 13 18:48:46 zynthian startx[8431]: Cannot connect to server socket err = No such file or directory
Aug 13 18:48:46 zynthian startx[8431]: Cannot connect to server request channel
Aug 13 18:48:46 zynthian startx[8431]: jackdmp 1.9.14
Aug 13 18:48:46 zynthian startx[8431]: Copyright 2001-2005 Paul Davis and others.
Aug 13 18:48:46 zynthian startx[8431]: Copyright 2004-2016 Grame.
Aug 13 18:48:46 zynthian startx[8431]: Copyright 2016-2019 Filipe Coelho.
Aug 13 18:48:46 zynthian startx[8431]: jackdmp comes with ABSOLUTELY NO WARRANTY
Aug 13 18:48:46 zynthian startx[8431]: This is free software, and you are welcome to redistribute it
Aug 13 18:48:46 zynthian startx[8431]: under certain conditions; see the file COPYING for details
Aug 13 18:48:46 zynthian startx[8431]: JACK server starting in realtime mode with priority 10
Aug 13 18:48:46 zynthian startx[8431]: self-connect-mode is "Don't restrict self connect requests"
Aug 13 18:48:47 zynthian startx[8431]: creating alsa driver ... hw:0|hw:0|1024|2|48000|0|0|nomon|swmeter|-|32bit
Aug 13 18:48:47 zynthian startx[8431]: ALSA: Cannot open PCM device alsa_pcm for capture. Falling back to playback-only mode
Aug 13 18:48:47 zynthian startx[8431]: configuring for 48000Hz, period = 1024 frames (21.3 ms), buffer = 2 periods
Aug 13 18:48:47 zynthian startx[8431]: ALSA: final selected sample format for playback: 16bit little-endian
Aug 13 18:48:47 zynthian startx[8431]: ALSA: use 2 periods for playback
Aug 13 18:48:47 zynthian startx[8431]: DEBUG:zynthian_config.get_disabled_midi_in_ports: DISABLED_MIDI_IN = ['']
Aug 13 18:48:47 zynthian startx[8431]: DEBUG:zynthian_config.get_enabled_midi_out_ports: ENABLED_MIDI_OUT = ['ttymidi:MIDI_out']
Aug 13 18:48:47 zynthian startx[8431]: DEBUG:zynthian_config.get_enabled_midi_fb_ports: ENABLED_MIDI_FB = ['']
Aug 13 18:48:47 zynthian startx[8431]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
Aug 13 18:48:47 zynthian startx[8431]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
Aug 13 18:48:47 zynthian startx[8431]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
Aug 13 18:48:47 zynthian startx[8431]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
Aug 13 18:48:47 zynthian startx[8431]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
Aug 13 18:48:47 zynthian startx[8431]: libzynmixer: Registering as 'zynmixer'.
Aug 13 18:48:47 zynthian startx[8431]: libzynmixer: Created input ports
Aug 13 18:48:47 zynthian startx[8431]: libzynmixer: Registered output ports
Aug 13 18:48:47 zynthian startx[8431]: libzynmixer: Activated client
Aug 13 18:48:49 zynthian startx[8431]: INFO:zynthian_gui.<module>: STARTING ZYNTHIAN-UI ...
Aug 13 18:48:49 zynthian startx[8431]: INFO:zynthian_gui_keybinding.load: Loading key binding from keybinding.yaml
Aug 13 18:48:49 zynthian startx[8431]: DEBUG:zynthian_gui_keybinding.load: Loading default keyboard bindings.
Aug 13 18:48:49 zynthian startx[8431]: INFO:zynthian_gui.zynswitches_init: INIT 0 ZYNSWITCHES ...
Aug 13 18:48:49 zynthian startx[8431]: INFO:zynthian_gui.zynswitches_midi_setup: CUSTOM I/O SETUP...
Aug 13 18:48:49 zynthian startx[8431]: DEBUG:zynthian_engine_mixer.get_controllers_dict: MIXER CTRL LIST: ['']
Aug 13 18:48:49 zynthian startx[8431]: Invalid card number.
Aug 13 18:48:49 zynthian startx[8431]: ERROR:zynthian_engine_mixer.get_mixer_zctrls: Command 'amixer -M -c pisound' returned non-zero exit status 1.
Aug 13 18:48:50 zynthian startx[8431]: INFO:zynthian_gui_midi_recorder.__init__: midi recorder created
Aug 13 18:48:50 zynthian startx[8431]: INFO:zynthian_gui.osc_init: ZYNTHIAN-UI OSC server running in port 1370
Aug 13 18:48:50 zynthian startx[8431]: INFO:zynthian_gui_admin.stop_rtpmidi: STOPPING RTP-MIDI
Aug 13 18:48:50 zynthian startx[8431]: JackGraphManager::Disconnect not connected port_src = 28 port_dst = 93
Aug 13 18:48:51 zynthian startx[8431]: INFO:zynthian_gui_admin.stop_qmidinet: STOPPING QMIDINET
Aug 13 18:48:51 zynthian startx[8431]: INFO:zynthian_gui_admin.start_touchosc2midi: STARTING touchosc2midi
Aug 13 18:48:56 zynthian startx[8431]: Jack main caught signal 15
Aug 13 18:48:56 zynthian startx[8431]: xinit: connection to X server lost
Aug 13 18:48:56 zynthian startx[8431]: [1B blob data]
Aug 13 18:48:56 zynthian startx[8431]: waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
Aug 13 18:48:57 zynthian startx[8431]: xinit: unexpected signal 15
Aug 13 18:48:57 zynthian systemd[1]: zynthian_debug.service: Main process exited, code=exited, status=1/FAILURE
Aug 13 18:48:57 zynthian systemd[1]: zynthian_debug.service: Failed with result 'exit-code'.
Aug 13 18:48:57 zynthian systemd[1]: Stopped Zynthian User Interface (DEBUG).
Have got any idea what is wrong?
