Improvements in update system: stable, staging & testing
Yes, moving towards PEP8 compliance has been a long time aspiration and we had to bite the bullet at some point. We tried several times in the past but if you don’t do it and publish quickly then you have problems with other developments (as you experienced). Indeed, we have several devices branches that will need to be similarly merged. It’s a headache.
Just curious, have you ever considered adapting semantic versioning and using Gitflow or trunk based development?
No. We never considered this “semantic versioning” and we don’t plan to do it in the short term.
Regarding “gitflow”, we are not far from it. Indeed, we could say that we currently follow the main guidelines from gitflow and our current version tree is quite similar to this one:
where our current “develop” branch is called “vangelis” and our current “release branch” (staging) is called “oram”, where we set the “stable” tags. We don’t have a separated “master” branch for the stable “tags”. We tag directly in the staging branch.
That’s why I asked :wink:
you seem to have a strong opinion against semantic versioning, considering that it is almost industry standard by now, is there a special reason?
I’m not against it, but IMHO, it doesn’t fit our development model and it’s “too bureaucratic”.
ZynthianOS is composed of many packages, with the zynthian specific software on top of them.
This zynthian specific software is splitted in several repositories:
  • zynthian-ui
  • zyncoder
  • zynthian-webconf
  • zynthian-sys
  • zynthian-data
these repositories evolve separately, but there are dependencies between them. Having a “common semantic version” for all of them have no sense and having a “specific semantic version” for each would be hard to maintain. It would make things more complex and i doubt the benefit is worth the effort.
We have found a kind of “zen” with our current “kind of gitflow” with lovely “branch names” and we would like to keep things like this for a while, so we can evaluate if this fits our development model.
Well, we fail with the first requirement of semantic versioning:
We aspire to this but are not there yet. I have tended to use semantic versioning for the past few decades for most of the libraries and applications that I have written and in some ways you can consider zynthian to do similar in that it has a major release (Oram 2409) and a minor (.1) although the minor and patch are the same - which is not uncommon for OS. zynthian is not a single library or application. It is a whole operating system. Look at how Ubuntu use major/point release or Mac and Windows use similar.
As @jofemodo describes, we don’t want the administrative overhead of managing lots of versioning. Each module, the whole system, etc. So we are trying this approach and seeing how it goes. The problems experienced recently are not due to the versioning system but instead, due to the implementation. As long as the developers and users can uniquely identify the state of a system (fairly simply) then we are achieving our goal and the simpler it is for everyone, the better. Now where did I put my riban version 1234.5678.90000?
For a RPi and Zynthian beginner like me: Is there more to do to switch from stable PR to vangelis than changing repositories and update? Just because I tried that lately and it was booting to “Software Error”. I have not entiely understood the error log practices, but one I found was that in some pyscripts it reported to miss some tkinter-web module.
Also, given that switching to vangelis exclusively does some apt stuff, can you even revert to stable simply by changing repositories and update? (For me it didn’t work because with updating webconf was dead also and I did not find out already how the alternative git checkout procedure works, so I just flashed stable again)
WHAT HAVE I DONE ‽‽‽
No ssh, no pong, nothing… Oh well… It’s probably time for a fresh install anyway and I can spare some time getting to know this oram of yours. So far, she has only told me of her md5sum (which of course I already knew : I just wanted to assert if I could trust her). It was hard of an information to get though after about an hour of rescuing multiple failed downloads… I even had to finish her off with the old wget --continue trick.
For the record, I was updated from the “testing” branch, rebooted and simply switched to the “oram” branch and started the update which failed in picrelated fashion.
I got four shows next week starting Thursday so I got to get to work. :fearful: :scream: :face_with_open_eyes_and_hand_over_mouth:
Hi @PeterLuck.
I just tested this and found that a change made to environmental variables ZYNTHIAN_UI_TOUCH_NAVIGATION in vangelis (testing)is blocking the movement between vangelis (testing), staging (oram) and stable (oram 2409.002). There is also an issue (I think with the use of environmental variables to define the current version) that means that running update scripts after checking out a branch, reverts to an unexpected branch, e.g. checkout vangelis, run update, reverts to stable.
It took me a while to get a working system after moving from vangelis to oram stable today. I hope that the next point release will resolve some of these issues.
I just realized the change in Daphne’s face…
Wow! Kudos to, I assume, @jofemodo .
Less rook soup tonight for everybody!!!
Finaliy you catch It :laughing:
+10 for @PeterLuck
I managed to brick one of my Zynthian SD cards yesterday (which was running a by now fairly old version of oram) by accidentally going into the Upgrade function in the UI and backing out of it (bold press on Back). After that Zynthian wouldn’t boot. Rather than spend potentially fruitless hours finding out if I could patch up the failed upgrade, I decided to start afresh. (At the time I was rather annoyed as I was in the middle of a MiMI-d debugging session, and besides I had a custom kernel with support for my newly acquired but by now rather old CME UF6 master keyboard).
Just reflashing the oram-2409 image that I’d started with once on this SD card and updating from there didn’t work completely; for one thing the webconf wouldn’t start, possibly because the manifest.ttl file for Dexed was corrupted.
So I decided to start afresh and download the latest oram image.
I did notice that there is both a tagged version
(2025-03-29-zynthianos-oram-2503-stable.img) and a non-tagged ‘latest stable’ (zynthianos-last-stable.img.xz). What is the idea here, that last-stable is the latest tagged one, quite simply?
One thing I did notice after downloading, flashing the card, and booting up (which all went well, no errors this time and webconf was working again), was that the output volume was very low (on my V4 Zynthian). After adding the output volume to the audio hardware mixer controls in the webconf, the UI showed that it was set to 10 instead of 100. Easy enough to fix, but I might not have known where to look if I hadn’t accidentally stumbled across the audio mixer pages at some earlier time. Is this something related to V5 being the default Zynthian platform or something else?
I had exactly the same problem.
