Hi Fernando,
quick question regarding the input jacks.
My V3 kit came with the hifiberry standard back in the day. From what I understand it has 6 pins on the board for inputs. The original input jack of my V3 is connected to pins 1 to 3 which I understand it’s basically the connection for the right channel.
So I guess I could connect the additional jack you included in the shipment to pins 4 and 5. But there is only 1 ground connector on the 6 input pins on the hifiberry. Can I simply connect the black cable of the second input jack to a different GND pin on the hifiberry or would I need to solder ground of jack 1 to jack 2?
I’m not an electronics expert so I hope I was able to explain well enough what the issue is.
Any feedback is appreciated.
Have a great weekend.
Greetings,
Markus
