Is a vector synth available?
haven’t found nothing yet.
AFAIK, no free software VS available …
A MIDI controlled mixer as described elsewhere & XY control perhaps could be implemented ?
well which engine could handle 4 wavetables for blending at once?
the controller for it is the easiest part I think.
The Sorcer synth seems to be the best morph-capable wavetable synth that’s open-source. However, it’s a 2-osc, not 4-osc architecture. It may be a point for you to start exploring, though? Especially if you can load the VS wavetables into it.
has someone tried to integrate in in zynthian yet?
Sorcer is included in the latest night builds. I’ve tested with it and it works really fine, although the package only include 5 factory presets.
I’m working on fixing the current problems with the nightly builds and hope to have it solved in a few days, OK?
ah.ok.didnt know that it was sorcer.
is or will there be a way to import own tables?
anyway… jofemodo=hero of the day…oehm year.
hmmmmm you don’t mean the calw wavetable engine?
tryed the sorcer engine today.
no output if I select one of the presets.
What SD image are you using? I’m afraid that it only work on recent nightly builds, and currently all of them are broken … I will try to solve it ASAP …
the image from 21.03.2020
I downloaded 11.08.2020 but I couldn’t get it running on the pi3.
that was the latest tracked green image.
wrecked my 21.03.2020 install with apt-get update and upgrade
so I thought its time too get a newer imager and kernel perhaps.
