Hello Everyone,
I am a proud owner of a new Zynthian.
I put the v4 kit together as instructed but when I enable to HifiBerry ADC DAC + Pro, the Zynthian boots in the error screen.
When switched to the internal headphones, the device starts and is operable.
I am using the standard settings for the hifiberry as per Zynthian.
This is the log I have been able to retrieve:
Oct 08 14:20:43 zynthian startx[907]: INFO:zynthian_gui_config.: ZYNTHIAN-UI CONFIG …
Oct 08 14:20:43 zynthian startx[907]: INFO:zynthian_gui_config.: Wiring Layout MCP23017_ZynScreen
Oct 08 14:20:43 zynthian startx[907]: DEBUG:zynthian_gui_config.: ZYNCODER A: [102, 105, 110, 113]
Oct 08 14:20:43 zynthian startx[907]: DEBUG:zynthian_gui_config.: ZYNCODER B: [101, 104, 109, 112]
Oct 08 14:20:43 zynthian startx[907]: DEBUG:zynthian_gui_config.: SWITCHES layout: [100, 103, 108, 111, 106, 107, 114, 115]
Oct 08 14:20:43 zynthian startx[907]: DEBUG:zynthian_config.get_disabled_midi_in_ports: DISABLED_MIDI_IN = [’’]
Oct 08 14:20:43 zynthian startx[907]: DEBUG:zynthian_config.get_enabled_midi_out_ports: ENABLED_MIDI_OUT = [‘ttymidi:MIDI_out’]
Oct 08 14:20:43 zynthian startx[907]: DEBUG:zynthian_config.get_enabled_midi_fb_ports: ENABLED_MIDI_FB = [’’]
Oct 08 14:20:43 zynthian startx[907]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
Oct 08 14:20:43 zynthian startx[907]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
Oct 08 14:20:43 zynthian startx[907]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
Oct 08 14:20:43 zynthian startx[907]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
Oct 08 14:20:43 zynthian startx[907]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
Oct 08 14:20:45 zynthian startx[907]: INFO:zynthian_gui.: STARTING ZYNTHIAN-UI …
Oct 08 14:20:45 zynthian startx[907]: INFO:zynthian_gui_keybinding.load: Loading key binding from keybinding.yaml
Oct 08 14:20:45 zynthian startx[907]: DEBUG:zynthian_gui_keybinding.load: Loading default keyboard bindings.
Oct 08 14:20:54 zynthian startx[907]: Cannot open jackpeak client
Oct 08 14:20:54 zynthian startx[907]: Cannot read socket fd = 7 err = Success
Oct 08 14:20:54 zynthian startx[907]: JackShmReadWritePtr1::~JackShmReadWritePtr1 - Init not done for -1, skipping unlock
Oct 08 14:20:54 zynthian startx[907]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Oct 08 14:20:54 zynthian startx[907]: libjackpeak failed to start jack client: 33
Oct 08 14:20:55 zynthian startx[907]: PNG file: /zynthian/config/img/fb_zynthian_error_ip.png - Application must supply a known background gamma
Oct 08 14:20:55 zynthian startx[907]: /zynthian/config/img/fb_zynthian_error_ip.png is 480x320 PNG image, color type RGB_ALPHA, 8 bit, file gamma 0.4546
Oct 08 14:20:55 zynthian startx[907]: Zooming image by 100%…done
Oct 08 14:20:55 zynthian startx[907]: Merging…done
Oct 08 14:20:55 zynthian startx[907]: Building XImage…done
Oct 08 14:20:58 zynthian startx[907]: Unable to connect to X server
Audio settings:
-P 70 -t 2000 -s -d alsa -d hw:sndrpihifiberry -S -r 44100 -p 256 -n 2 -X raw
root@zynthian:~# aplay -l
card 1: b1 [bcm2835 HDMI 1], device 0: bcm2835 HDMI 1 [bcm2835 HDMI 1]
Subdevices: 4/4
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
card 2: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 4/4
card 4: sndrpihifiberry [snd_rpi_hifiberry_dacplusadcpro], device 0: HiFiBerry DAC+ADC Pro HiFi multicodec-0 [HiFiBerry DAC+ADC Pro HiFi multicodec-0]
Subdevices: 0/1
Any ideas on what to do next?
Would love to have inputs and outputs
Thanks in advance and looking forward to joining the community!
Kindest Regards,
Weirdbrainwaves
