Hello,
I am facing trouble with my Zynthian setup and need any help / suggestions. Whenever I try to load the “MIDI Synth” plugin, I receive an error message stating “Failed to Initialize.” This issue occurs consistently every time I try to use this plugin. The error message appears immediately after selecting the plugin from the list and does not proceed to the plugin interface.
I have restarted the Zynthian device multiple times, but the problem exist .
I have updated to the latest Zynthian software version available.
I’ve checked all connections and ensured that the MIDI Synth plugin is properly installed. Details are -
Zynthian Version: 2024-07-10
Plugin in Use: MIDI Synth
Error Message: “Failed to Initialize”
I’ve reviewed the Zynthian Users Guide - ZynthianWiki splunk documentation and searched through the forums but haven’t found a solution. If anyone has experienced this issue or has any troubleshooting tips, I would greatly appreciate your input.
Thank you in advance for your assistance!
Best regards,
