Load snapshot through web-ui?
Is it possible to actually load a snapshot through the web-ui ?
I see options to dowload, delete etc., but missing a “load” button.
No, It’s not expected that you would be using the webui while performing. If you want you can set a ‘default’ snapshot that loads on boot though. You can also send MIDI program changes on ch16, or in single channel mode, to load snapshots.
All right, MIDI might be the way to go. I am just looking for ways to (re)load snapshots fairly quickly without reboot etc. when the UI is stuck. I unfortunately experienced that a couple of times after doing changes to my setup that uses MIDI-USB devices.
Yes, i think MIDI->CUIA is the way. You can restart UI without rebooting and also load snapshots.
