Hello,
I am havin trouble with the zynthian standard login.
Neither direct on cli with display, via ssh, or web interface. On the web interface, I can at least check, that the password is correct, because it outputs the error “Authentication Failure” when trying to loing instead of “incorrect password” when using a wrong password (yes, I tried different chromium browsers, firefox+developer edition, +all in mobile version, clearing cache and using private mode, also setting time manually although ntp configured it correctly).
I think, that maybe there is a problem with the initial configuration?? I don´t know why tho, I even tried setting it up in minimal configuration with just the raspberri pi4, so the hardware shouldn´t be different from all others.
I also just installed a clean image of Raspberri Pi OS with all my hardware attached and it configured completely on first install, even the touchscreen is working.
Here is my Hardware:
-Raspberri Pi4
-InnoMaker HiFi DAC HAT PCM5122
-Freenove 5" 800x480 IPS Touchscreen
-SanDisk Extreme 64GB Micro-SD-Card
-65W Lenovo Universal USB-C PSU (2A@5V) (tried others)
Images used:
-2306
-2308
Imager Softwares used:
-Rufus
-RPI Imager
-USBIT
Additional:
-tried with and withouth Ethernet connected at first boot
-MD5 Hash checked
