I’ve noticed that in certain cases the UI can be ambiguous because of long file names.
For instance, using LinuxSampler to select SFZ’s. If SFZ/Other is chosen, there are a list of titles that look identical “sonatina/Sonatina Symphonic Orc”. The unique part of each SFZ name is off-screen on a Zynthian V3.
It would seem that automatically scrolling long titles like this would be a nice feature. This is already implemented in the actual instrument UI but not in the selection screen.
Also, is there a setting to change the scroll rate?
but that doesnt seem to be possible.
you can only rename the ending, for example “Strings - 1st Violins Sustain”.
The entire “sonatina/Sonatina Symphonic Orchestra/” doesnt appear in the edit window
