May 01 09:14:04 audiodev startx[2288]: INFO:zynthian_engine.start: Starting Engine Jalv/SpectralFX
May 01 09:14:04 audiodev startx[2288]: DEBUG:zynthian_engine.start: Command: jalv.gtk --jack-name SpectralFX-00 https://www.ponkia.com/plugins/spectralfx/
May 01 09:14:05 audiodev startx[2288]: DEBUG:zynthian_engine_jalv.init: Jack Name => SpectralFX-00
May 01 09:14:05 audiodev startx[2288]: INFO:zynthian_engine_jalv.init: No defined MIDI controllers for ‘SpectralFX’.
May 01 09:14:05 audiodev startx[2288]: INFO:zynthian_engine_jalv.get_lv2_controllers_dict: Getting Controller List from LV2 Plugin …
May 01 09:14:05 audiodev startx[2288]: DEBUG:zynthian_config.get_disabled_midi_in_ports: DISABLED_MIDI_IN = [‘’]
May 01 09:14:05 audiodev startx[2288]: DEBUG:zynthian_config.get_enabled_midi_out_ports: ENABLED_MIDI_OUT = [‘ttymidi:MIDI_out’]
May 01 09:14:05 audiodev startx[2288]: DEBUG:zynthian_config.get_enabled_midi_fb_ports: ENABLED_MIDI_FB = [‘’]
May 01 09:14:05 audiodev startx[2288]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
May 01 09:14:05 audiodev startx[2288]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
May 01 09:14:05 audiodev startx[2288]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
May 01 09:14:05 audiodev startx[2288]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
May 01 09:14:05 audiodev startx[2288]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
May 01 09:14:05 audiodev startx[2288]: INFO:zynthian_gui_admin.stop_rtpmidi: STOPPING RTP-MIDI
May 01 09:14:06 audiodev startx[2288]: INFO:zynthian_gui_admin.stop_qmidinet: STOPPING QMIDINET
May 01 09:14:06 audiodev startx[2288]: INFO:zynthian_gui_admin.stop_touchosc2midi: STOPPING touchosc2midi
May 01 09:14:07 audiodev startx[2288]: INFO:zynthian_gui_admin.stop_aubionotes: STOPPING aubionotes
May 01 09:14:07 audiodev startx[2288]: DEBUG:zynthian_layer.load_bank_list: BANK LIST =>
May 01 09:14:07 audiodev startx[2288]: [(‘None’, None, ‘None’, None)]
May 01 09:14:07 audiodev startx[2288]: INFO:zynthian_layer.set_bank: Bank Selected: None (0)
May 01 09:14:07 audiodev startx[2288]: DEBUG:zynthian_layer.reset_preset: PRESET RESET!
May 01 09:14:07 audiodev startx[2288]: DEBUG:zynthian_layer.load_preset_list: PRESET LIST =>
May 01 09:14:07 audiodev startx[2288]: [[‘https://www.ponkia.com/plugins/spectralfx/:preset1’, None, ‘’, ‘None’]]
May 01 09:14:07 audiodev startx[2288]: [(‘’, None, ‘’, None)]
May 01 09:14:07 audiodev startx[2288]: DEBUG:zynthian_gui.set_active_channel: ACTIVE CHAN: -1 => 0
May 01 09:14:07 audiodev startx[2288]: INFO:zynthian_gui.zynswitches_midi_setup: MIDI SWITCHES SETUP…
May 01 09:14:07 audiodev startx[2288]: INFO:zynthian_gui.zynswitches_midi_setup: MIDI ZYNSWITCH 4: 12 CH#0, 1, 0
May 01 09:14:07 audiodev startx[2288]: INFO:zynthian_gui.zynswitches_midi_setup: MIDI ZYNSWITCH 5: 12 CH#0, 2, 0
May 01 09:14:07 audiodev startx[2288]: INFO:zynthian_gui.zynswitches_midi_setup: MIDI ZYNSWITCH 6: 12 CH#0, 3, 0
May 01 09:14:07 audiodev startx[2288]: INFO:zynthian_gui.zynswitches_midi_setup: MIDI ZYNSWITCH 7: 12 CH#0, 4, 0
May 01 09:14:07 audiodev startx[2288]: INFO:zynthian_gui_stepsequencer.restore_riff_data: Restoring RIFF data…
May 01 09:14:07 audiodev startx[2288]: DEBUG:zynthian_gui_bank.show: BANK INDEX => 0
May 01 09:14:07 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Bank’: 0 (0 → 1), None, None
May 01 09:14:07 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Preset’: 0 (0 → 1), None, None
May 01 09:14:07 audiodev startx[2288]: INFO:zynthian_layer.set_preset: Preset Selected: (0)
May 01 09:14:07 audiodev startx[2288]: DEBUG:zynthian_gui_control.set_controller_screen: SET CONTROLLER SCREEN Ctrls#1
May 01 09:14:07 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Upper Compression’: 1.0 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:14:07 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Overdrive’: 0.0 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:14:07 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Upper Threshold [dB]’: -31.799999 (-120.0 → 0.0), None, None
May 01 09:14:07 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Upper Gain [dB]’: -66.0 (-120.0 → 120.0), None, None
May 01 09:17:01 audiodev startx[2288]: DEBUG:zynthian_gui_control.set_controller_screen: SET CONTROLLER SCREEN Ctrls#3
May 01 09:17:01 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Normalize volume’: 1.0 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:17:01 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Bypass’: 0.0 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:17:04 audiodev startx[2288]: DEBUG:zynthian_gui_controller.cb_canvas_release: CONTROL 1 RELEASE => 0.224209, 49.06136684968043
May 01 09:17:08 audiodev startx[2288]: DEBUG:zynthian_gui_controller.cb_canvas_release: CONTROL 1 RELEASE => 0.161447, 37.16389898852255
May 01 09:28:42 audiodev startx[2288]: DEBUG:zynthian_gui_controller.cb_canvas_release: CONTROL 1 RELEASE => 0.181195, 44.15132867904744
May 01 09:28:43 audiodev startx[2288]: DEBUG:zynthian_gui_controller.cb_canvas_release: CONTROL 1 RELEASE => 0.160336, 37.42141502844027
May 01 09:28:47 audiodev startx[2288]: DEBUG:zynthian_gui_controller.cb_canvas_release: CONTROL 1 RELEASE => 0.139231, 21.546925612830478
May 01 09:28:48 audiodev startx[2288]: DEBUG:zynthian_gui_controller.cb_canvas_release: CONTROL 1 RELEASE => 0.11748, 8.512087163772557
May 01 09:28:48 audiodev startx[2288]: INFO:zynthian_gui.zynswitch_short: Short Switch 1
May 01 09:28:48 audiodev startx[2288]: DEBUG:zynthian_gui.zynswitch_short: BACK TO SCREEN => layer
May 01 09:28:48 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Layer’: 0 (0 → 10), None, None
May 01 09:28:50 audiodev startx[2288]: INFO:zynthian_gui.zynswitch_short: Short Switch 3
May 01 09:28:50 audiodev startx[2288]: DEBUG:zynthian_layer.load_bank_list: BANK LIST =>
May 01 09:28:50 audiodev startx[2288]: [(‘None’, None, ‘None’, None)]
May 01 09:28:50 audiodev startx[2288]: DEBUG:zynthian_layer.load_preset_list: PRESET LIST =>
May 01 09:28:50 audiodev startx[2288]: [[‘https://www.ponkia.com/plugins/spectralfx/:preset1’, None, ‘’, ‘None’]]
May 01 09:28:50 audiodev startx[2288]: DEBUG:zynthian_gui_bank.show: BANK INDEX => 0
May 01 09:28:50 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Bank’: 0 (0 → 1), None, None
May 01 09:28:50 audiodev startx[2288]: INFO:zynthian_layer.set_bank: Bank Selected: None (0)
May 01 09:28:50 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Preset’: 0 (0 → 1), None, None
May 01 09:28:50 audiodev startx[2288]: INFO:zynthian_layer.set_preset: Preset Selected: (0)
May 01 09:28:50 audiodev startx[2288]: DEBUG:zynthian_gui_control.set_controller_screen: SET CONTROLLER SCREEN Ctrls#3
May 01 09:28:50 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Normalize volume’: 1.0 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:28:50 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Bypass’: 0.0 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:33:57 audiodev startx[2288]: DEBUG:zynthian_gui_control.set_controller_screen: SET CONTROLLER SCREEN Ctrls#1
May 01 09:33:57 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Upper Compression’: 1.0 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:33:57 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Overdrive’: 0.0 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:33:57 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Upper Threshold [dB]’: -31.799999 (-120.0 → 0.0), None, None
May 01 09:33:58 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Upper Gain [dB]’: -66.0 (-120.0 → 120.0), None, None
May 01 09:33:59 audiodev startx[2288]: DEBUG:zynthian_gui_control.set_controller_screen: SET CONTROLLER SCREEN Ctrls#2
May 01 09:33:59 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Lower Compression’: 1.0 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:33:59 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Underdrive’: 0.0 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:33:59 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Lower Threshold [dB]’: 0.0 (-120.0 → 0.0), None, None
May 01 09:33:59 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Lower Gain [dB]’: 25.200001 (-120.0 → 120.0), None, None
May 01 09:34:01 audiodev startx[2288]: DEBUG:zynthian_gui_control.set_controller_screen: SET CONTROLLER SCREEN Ctrls#1
May 01 09:34:01 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Upper Compression’: 1 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:34:01 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Overdrive’: 0 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:34:01 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Upper Threshold [dB]’: -31.799999999999997 (-120.0 → 0.0), None, None
May 01 09:34:21 audiodev startx[2288]: ERROR:zynthian_engine.proc_cmd: Can’t exec engine command: set 7 -31.800000 => Timeout exceeded.
May 01 09:34:21 audiodev startx[2288]: <pexpect.pty_spawn.spawn object at 0xac9d1a70>
May 01 09:34:21 audiodev startx[2288]: command: /usr/local/bin/jalv.gtk
May 01 09:34:21 audiodev startx[2288]: args: [‘/usr/local/bin/jalv.gtk’, ‘–jack-name’, ‘SpectralFX-00’, ‘https://www.ponkia.com/plugins/spectralfx/’]
May 01 09:34:21 audiodev startx[2288]: buffer (last 100 chars): b’set 7 0.000000\r\nupper_threshold = 0.000000\r\n> ’
May 01 09:34:21 audiodev startx[2288]: before (last 100 chars): b’set 7 0.000000\r\nupper_threshold = 0.000000\r\n> ’
May 01 09:34:21 audiodev startx[2288]: after: <class ‘pexpect.exceptions.TIMEOUT’>
May 01 09:34:21 audiodev startx[2288]: match: None
May 01 09:34:21 audiodev startx[2288]: match_index: None
May 01 09:34:21 audiodev startx[2288]: exitstatus: None
May 01 09:34:21 audiodev startx[2288]: flag_eof: False
May 01 09:34:21 audiodev startx[2288]: pid: 2421
May 01 09:34:21 audiodev startx[2288]: child_fd: 31
May 01 09:34:21 audiodev startx[2288]: closed: False
May 01 09:34:21 audiodev startx[2288]: timeout: 20
May 01 09:34:21 audiodev startx[2288]: delimiter: <class ‘pexpect.exceptions.EOF’>
May 01 09:34:21 audiodev startx[2288]: logfile: None
May 01 09:34:21 audiodev startx[2288]: logfile_read: None
May 01 09:34:21 audiodev startx[2288]: logfile_send: None
May 01 09:34:21 audiodev startx[2288]: maxread: 2000
May 01 09:34:21 audiodev startx[2288]: ignorecase: False
May 01 09:34:21 audiodev startx[2288]: searchwindowsize: None
May 01 09:34:21 audiodev startx[2288]: delaybeforesend: 0
May 01 09:34:21 audiodev startx[2288]: delayafterclose: 0.1
May 01 09:34:21 audiodev startx[2288]: delayafterterminate: 0.1
May 01 09:34:21 audiodev startx[2288]: searcher: searcher_re:
May 01 09:34:21 audiodev startx[2288]: 0: re.compile(b’\n> ')
May 01 09:34:21 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Upper Gain [dB]’: -66.0 (-120.0 → 120.0), None, None
May 01 09:34:21 audiodev startx[2288]: DEBUG:zynthian_gui_control.set_controller_screen: SET CONTROLLER SCREEN Ctrls#2
May 01 09:34:21 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Lower Compression’: 1 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:34:21 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Underdrive’: 0 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:34:21 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Lower Threshold [dB]’: 0.0 (-120.0 → 0.0), None, None
May 01 09:34:21 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Lower Gain [dB]’: 25.19999999999999 (-120.0 → 120.0), None, None
May 01 09:34:21 audiodev startx[2288]: DEBUG:zynthian_gui_control.set_controller_screen: SET CONTROLLER SCREEN Ctrls#3
May 01 09:34:21 audiodev startx[2288]: ERROR:zynthian_gui_controller.calculate_plot_values: Calc Error => list index out of range
May 01 09:34:21 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Normalize volume’: 1 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:34:21 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Bypass’: 0 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:34:25 audiodev startx[2288]: DEBUG:zynthian_gui_control.set_controller_screen: SET CONTROLLER SCREEN Ctrls#2
May 01 09:34:25 audiodev startx[2288]: ERROR:zynthian_gui_controller.calculate_plot_values: Calc Error => list index out of range
May 01 09:34:25 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Lower Compression’: 1 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:34:25 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Underdrive’: 0 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:34:25 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Lower Threshold [dB]’: 0.0 (-120.0 → 0.0), None, None
May 01 09:34:25 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Lower Gain [dB]’: 25.19999999999999 (-120.0 → 120.0), None, None
May 01 09:34:26 audiodev startx[2288]: DEBUG:zynthian_gui_control.set_controller_screen: SET CONTROLLER SCREEN Ctrls#1
May 01 09:34:26 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Upper Compression’: 1 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:34:26 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Overdrive’: 0 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:34:26 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Upper Threshold [dB]’: 0.0 (-120.0 → 0.0), None, None
May 01 09:34:26 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Upper Gain [dB]’: -66.0 (-120.0 → 120.0), None, None
May 01 09:34:27 audiodev startx[2288]: DEBUG:zynthian_gui_control.set_controller_screen: SET CONTROLLER SCREEN Ctrls#3
May 01 09:34:27 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Normalize volume’: 1 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:34:27 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Bypass’: 0 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:34:28 audiodev startx[2288]: DEBUG:zynthian_gui_control.set_controller_screen: SET CONTROLLER SCREEN Ctrls#3
May 01 09:34:28 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Normalize volume’: 1 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:34:28 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Bypass’: 0 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:34:28 audiodev startx[2288]: DEBUG:zynthian_gui_control.set_controller_screen: SET CONTROLLER SCREEN Ctrls#2
May 01 09:34:28 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Lower Compression’: 1 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:34:28 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Underdrive’: 0 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:34:28 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Lower Threshold [dB]’: 0.0 (-120.0 → 0.0), None, None
May 01 09:34:28 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Lower Gain [dB]’: 25.19999999999999 (-120.0 → 120.0), None, None
May 01 09:34:30 audiodev startx[2288]: DEBUG:zynthian_gui_control.set_controller_screen: SET CONTROLLER SCREEN Ctrls#3
May 01 09:34:30 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Normalize volume’: 1 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:34:30 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Bypass’: 0 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:38:29 audiodev startx[2288]: DEBUG:zynthian_gui_control.set_controller_screen: SET CONTROLLER SCREEN Ctrls#1
May 01 09:38:29 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Upper Compression’: 1 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:38:29 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Overdrive’: 0 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:38:29 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Upper Threshold [dB]’: 0.0 (-120.0 → 0.0), None, None
May 01 09:38:29 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Upper Gain [dB]’: -66.0 (-120.0 → 120.0), None, None
May 01 09:38:30 audiodev startx[2288]: DEBUG:zynthian_gui_control.set_controller_screen: SET CONTROLLER SCREEN Ctrls#2
May 01 09:38:30 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Lower Compression’: 1 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:38:30 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Underdrive’: 0 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:38:30 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Lower Threshold [dB]’: 0.0 (-120.0 → 0.0), None, None
May 01 09:38:30 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Lower Gain [dB]’: 25.19999999999999 (-120.0 → 120.0), None, None
May 01 09:38:32 audiodev startx[2288]: DEBUG:zynthian_gui_control.set_controller_screen: SET CONTROLLER SCREEN Ctrls#3
May 01 09:38:32 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Normalize volume’: 1 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:38:32 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Bypass’: 0 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:38:35 audiodev startx[2288]: DEBUG:zynthian_gui_control.set_controller_screen: SET CONTROLLER SCREEN Ctrls#1
May 01 09:38:35 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Upper Compression’: 1 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:38:35 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Overdrive’: 0 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:38:35 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Upper Threshold [dB]’: 0.0 (-120.0 → 0.0), None, None
May 01 09:38:35 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Upper Gain [dB]’: -66.0 (-120.0 → 120.0), None, None
May 01 09:38:35 audiodev startx[2288]: DEBUG:zynthian_gui_control.set_controller_screen: SET CONTROLLER SCREEN Ctrls#3
May 01 09:38:35 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Normalize volume’: 1 (0 → 1), [‘off’, ‘on’], [0, 1]
May 01 09:38:35 audiodev startx[2288]: DEBUG:zynthian_gui_controller.config: ZCTRL ‘Bypass’: 0 (0 → 1), [‘off’, ‘on’], [0, 1]
