Manual change version/repo
I made a mistake, I select in “software version “ the version “Testing (angels)” without update the Zynthian. When I want to change with “Stable (Oram-2506.1)” I have “ “500: Internal Server Error”.
How can I reverse to the Stable repo?
Many thanks
Best regards,
Antoine
Please try to let the update run. After this is finished, you may select Stable Oram and update again, if you really have to go back. After changing the version, do update.
Hi Fussy,
Don’t you think that will definitely crash the zynthian with no back possible to 2506?
I’ve changed versions from all possible versions to all others already and it worked. YMMV.
Now as the cards are so cheap, there is nothing against making another MicroSD for testing, in case you are afraid of shredding a precious installation.
Hi Fussl,
You are right, it’s ok now but the ethernet interface is now in ip fix (172.31.1.243) and not in DHCP. Do you know how to set it to DHCP?
Thanks,
Brgs
Antoine
Hi, @Letoine, you can try command “nmtui” from terminal and you Will get a text based menú to manage Network stuff.
I hope this Will help you.
It’s ok now I can set DHCP in the eth0.
