When I play with the Plugin “MDA DX10”, I cannot use the “Decay” in the “Envelope”-Tab. This always results in a very short and unusable sound. Is there something wrong with that Plugin? Do you also have the same problem with that Plugin?
I am also experiencing the same issue with the envelope in MDA DX10. However, all instrument presets work fine; they have proper decay times, lasting as long as a second.
At this point, I’ve given up on chasing the .ttl definitions.
also mine (Oram staging)
zyncoder: oram (ea17c87)
zynthian-ui: oram (11d4e85)
zynthian-sys: oram (7b1a2af)
zynthian-data: oram (781d76c)
zynthian-webconf: oram (0e2c255)
Yes it is broken. Some should probably raise a ticket for that…
I found that /zynthian/zynthian-plugins/lv2/mod-mda-DX10.lv2/DX10.ttl is the active configuration file. I can edit it and apply the changes by running systemctl restart zynthian. Now, I am exploring how to control the parameters more effectively.
Edit: Is the closed Issue #1141 related to this topic? Issue: Instrument: MDA DX10: Envelope -> Decay seems broken · Issue #1141 · zynthian/zynthian-issue-tracking · GitHub
