Hi, tell me how to find a MicroDexed build diagram - DX7
Do you mean a build manual? It’s here.
Regards, Holger
Thank you!
This video:
is a nice comparison between the original DX7, the commercial but very good software emulation DX7V by Arturia and the open source Dexed (whose sound engine is used for MicroDexed).
Have fun!
Thanx a lot… one day, a comparison video involving microDexed ?
Interesting.
On some sounds, for example the harpsichord, I will prefer Dexed… on others, I would prefer Arturia…
But most of the times, the différences are not sooooo big…
And what the video doesn’t tell is : which engine was Dexed set to ? Mark 1 ? Modern ?
Concerning microDexed, Holger already knows that I find its sound pleasantly warmer than Dexed… (I mean, Dexed on MY computer… from one computer to another, I guess it might sound different, depending on the sound card)…
But it’s true that Arturia UI is gorgeous…
I hope so… I am searching for an old DX7. If I can’t borrow one, I use my DX7II (which is known to have better output converters).
BTW: I also now have an Arturia DX7V license, so I can make a similar comparison.
Regards, Holger
Hi!
Now the Teensy-4.1-Adapter-Board is ready! After getting the PCBs I noticed that there is a 100 Ohm resistor needed in the MCLK line for Rev. A and B audio boards… so it’s a little bit tricky to add it to the adapter - but not impossible:
Added to MicroDexed it now looks a little bit untidy (note the tablecloth!):
But it works very nice! Two instances of 16 voices with FX are not a problem. Perhaps 24 or 32 voices per instance are possible?!?!
Regards, Holger
… and now there is also a small build manual for the adapter.
Hi @ll,
there are some kits available if you want to build your own MicroDexed for Xmas
. Also the Teensy-4.1 adapter board is now available.
Regards, Holger
How much? What does it contain and what else needs to be supplied?
I sent you a PM.
230V for the soldering iron…
So that what we’ve been doing wrong … ![]()
Dungeons 46 throu’ to 59 … JUST PLUG UM IN!!!
Are you sure that there is 230V socket inside your primitive dungeons ?
Well we should have an electrical certificate,
We definitely sent someone down to check but to be frank in all the work round here I quite forgot about him . . .
Perhaps the vultures got him…?
With Brexit I expect we will return to good old 240V a.c.
5v is the new 230V
Hi Roger, will the adapter board work with the version I have? If so, how much is it?
