Hey,
I seem to be doomed to tap into all stragness, like everytime, anywhere.
This time: random paramter fun.
OK, I did a vid showing this off.
In the vid I am using an expression pedal which is connected to a G2X Synth. This puts out MIDI CC 11 to the Zynthian.
I try it in words:
When I am at any page on the zynGUI with parameters on it, every CC I input to that ZynLayer (no matter whcih CC, with the same channel) will randomly change values on that page, evenn when there are no CCs assigned. I have not found a pattern but it is consistent on every Engine, be it MOD-UI or an instance of ZynAddSubFx.
Even stranger: I have ZynAddSubFx pn Layer 3 (and MIDI CH3). When I switch to preset selection it will randomly select a preset, but this time listening to CC on MIDI-Channel 1.
I have set golbal MIDI Channel to 16, see screenshot of MIDI-config:
I have observed incoming MIDI through a MIDI-Monitor. I can see incoming CCs but nothing strange happening at all.
Can someone confirm this, so we can put it on the zynthian / zynthian-issue-tracking
I can work around it - though it can obviously kill a live performance, when you are not cautious.
… but it is strange as a pink cat.
Setup: Raspbian GNU/Linux 10 (buster)
Build Date: 2020-09-05
Memory: 2% (217M/7899M)
zyncoder: stable (7c09738)
zynthian-ui: stable (30294c8)
zynthian-sys: stable (0bd40a7)
zynthian-data: stable (82571e7)
zynthian-webconf: stable (7961552)
Raspberry Pi 4 Model B Rev 1.4
Soundcard: HifiBerry DAC+ ADC PRO
Display: ZynScreen 3.5 (v1)
Wiring: MCP23017_ZynScreen GPIO Expander: MCP23017
