This is send by zynthian router. Remember the “tuning” feature. If you are playing with the pitch wheel, it will add the needed offset dynamically.
yes, ok, i remember.
But this is not the problem. The CC123 seems to be.
Or something completely different.
You could use x42 MIDI Splitter within MOD-UI. Link the MIDI input you want to feed to the spliter and the output to the Zynthian Master input. Add two instruments set to different channels then select the MOD-UI layer in single instrument mode. MIDI input is sent to the splitter and on to each instrument. This seems to work for me. This could be implemented in a native MIDI chain in the future but for now it looks like MOD-UI is the simplest way to do this.
Adding a simple keyboard split to the UI shouldn’t be too difficult. Not much more difficult than the transpose functions that is already implemented
thanks, that is it.
And I believe the name of the Song may not contain spaces.
This is already solved! Just update …
