I built a Zynthian Box with official Zynthian kit. Everything is working exept midi din.
I double checked connections and tried inverting the two wires but nothing is working …
Do someone experienced issues with midi din in?
Hi @Djeremaille!
It should work. I only can suggest that re-check the wiring, putting attetion to 2in1 to GPIO connection. Also, check the opto-coupler and diode orientation, correct soldering, etc.
Are you using Gorgona SD image?
So I triple checked and now it’s working!
…I’ve done nothing…
Great! Sometimes i think gremlins exists
Hi! Have you printed the 3D-printer box? Please, send some photos. I’m very curious about the result!
I will post my pictures this morning!
Hello. I’m using my Zynthian for a several months, but MIDI-IN is still doesn’t work.
So, when zynth have been disassembled at the very beginning it returned logo with “error” when runned - I’ve checked 2in1 board - one of chips was hot - I’ve checked wires - 6pin-connector was wired in reverse order - I’ve rewired and Zynth works.
But, MIDI-IN doesn’t work.
Is any way to check 2in1 board? I can use external RX-TX device to send or receive commands using serial port, or, maybe, some script exists for checking, or I can check it using multimeter?
and [topic offtop] second question: how to access shell when hdmi display connected? Before gorgona-image it was accessible, but not now.
Hi @quadrica!
For properly testing the 2in1 MIDI-IN circuit you will need a MIDI source (keyboard) and some kind of oscilloscope. You could try to make a software test, but if MIDI-IN doesn’t work with a fresh Gorgona image, it’s quite clear that it’s not a software problem.
A multimeter can be helpful for doing a quick CC test. You can check if there is a CC between connector pins, but it’s difficult to check if the optocoupler is OK.
I recommend you use a small metal brush to clean the surface of the PCB, and after that, do a visual inspection with a magnifying glass. If possible, send a photo.
Ups! I’ve never tried this with Gorgona. I always use SSH Let me try …
Kind Regards!
So,
I’ve checked wires - it was ok.
Now I’m experimenting with developing of midi interface for my live set-up, and, I decided to create simple arduino-based device, which can send midi-messages using TX port. I’ve used also schema of wiring because of voltage differencies between boards:
http://forum.arduino.cc/index.php?action=dlattach;topic=169537.0;attach=45235
It works!
After this little success I’ve decided to check the system using optocoupler schema:
I’ve developed it using prototype board, fortunately, I had all necessary components.
It works too!
I’ve placed this board inside Zynthian (temporary).
I suppose - optocoupler in 2in1 board is dead. Next time I will try to desolder it and exchange.
Thank you for instructions.
When I use the Gorgona image, I find that tty3 (or maybe tty2??) is occupied by the Zynthian UI with no window manager or desktop.
@quadrica No matter, this is why Linux has multiple Ttys–if you are using HDMI monitor and talking about shell, I assume you do NOT mean ssh. I assume you have a keyboard and mouse connected to your RPi… right?
If so, you can press Ctrl+Alt+F1 to get to tty1, Ctrl+Alt+F2 for tty2, and so on. Zynthian UI loads on tty3–just keep trying combinations above until you get a login prompt!
@quadrica I also just realized: if you want to use a desktop manager with your HDMI-connected monitor, you can install Openbox, apt-get install -y --force-yes openbox
and then run startx
to run it on that display once you’re at a prompt/shell. I use this and then launch the Zynthian UI inside a managed window for dev purposes. May not be what you’re looking for, but thought I would offer it up.
Thank you! I will try at evening.
hi, i also get a problem using the midi in, down have to enable something after a clean instal of Zynthian to make the midi din working? I already build midi in for Arduino so I had already checked my wiring and adapted the resistor but I can t debug my problem I use the exactly same schematic as in the last posts 5v to pin 02 on pi gnd on pin 06 and rx to pin 10 I already tried inverting din socket and also diode easyli cause I m on a breadboard, this interface work on my teensy like this so I think the problem is in the configuration and stil nothing, if someone has an idea it would be nice!
