Hi folks,
is there already a list with usb controllers that will work or got mapped right?
btw is an Akai mpk mini working directly or need bus power over an usb hub?
regards,
ingo
Hi folks,
regards,
ingo
I’ve run a zynthian rig from a battery pack with a Akai mpk 25 attached and no USB hub.
first sorry for my bloody rusty English. sigh
have you got it managed to get keys or knobs managed?
a list of working controllers would be fine.
perhaps I should buy a mini pad or something like that.
for on the road.
Not sure I know what you mean.
I have a couple of zynthian ALL-IN_ONE card which provides all the zynthian control (4 encoders), other than that pretty much may MIDI controller can be plugged in, and then use the mouse to assign the controls to the controllers and then save it add a snapshot. I don’t know if you speak french but there are youtube videos of zynth’s in French
If the USB MIDI device is ‘Class Compliant’ then it willl work with zynthian and you should be able to map the knobs and sliders to parameters of the zynth engines by following The Wiki
