Ah! I just tested and can confirm your behaviour. Assigning a CC to zynsampler transport then rebooting does not retain the CC mapping. Please add a ticket to the issue tracker and I will take a look. This is the same behaviour for any engine, not just zynsampler.
You mean I was right??? When @wyleu finds out… you’ll see…!!!
Jokes aside…Thanks for your endless commitment @riban…I’ll see if I can do what you say…
I hope I opened the ticket correctly… When I entered the project of my case it took me two days… I am truly incompetent in these things…
Strange… until yesterday I didn’t see the effects of the buttons I added on the Midi Log of WebConf… This morning… MIRACLE!!!
So the added buttons show their work even if they don’t make Zynthian do what they should…
@riban, I tried to install Vangelis on another SD… With this upgrade the two buttons work… I still have to see if they remain memorized but in the meantime they work.
Global MIDI binding is per device, per channel, per CC so it should be saved in the snapshot but only work for the same hardware controller / MIDI device.
After lunch I’ll try, but the important thing is that the buttons now interact and work, if then, in the meantime, I have to do the midi learn every time, it’s less important… Thanks.
Negative. Doesn’t remember. But at least the button works now.
