I am facing the problem with ZynMidiRouter - whenever I add/remove MIDI FX to the layer, routers stops per-channel routing of midi commands. When checking in patchage I can see connection are correct. Also, after reboot new configuration appears to work until I add/remove MIDI FX again. ZynMidiRouter also continues to send commands to midi_out/main_out (obviously, without filtering).
Any ideas where I can begin debugging it? I’ve run zynthian_debug service and checked journalctl -xe but could not see anything related to the midi router…
