I’m struggling a bit with the arranger part of the sequencer. I don’t understand which sequence the numbers correspond to. Also there seems to be a bug at least with the touch interface that when I try to select the sequence number, +1 adds 10 instead of 1. Also, if I add a new sequence in arranger view, long press from the pad view goes back to arranger rather than pattern edit.
push and rotate while pushing?
I only have touchpad input so that won’t work. There is definitely a bug with +1 adding 10 and +10 adding 100 though…
Just to reply to my own thread, the bug with +1 adds 10 is only in the arranger, which I have now realised is not 100% essential to my workflow. Would still be nice to be fixed tho.
