Might zynthian support (akai mpc) vst2 plugings?
Just a thought:
Currently only lv2 plugins are supported, but if the MPC vst2 plugins will become available by the MPC community, it might be interesting to see if zynthian can also install those (MPC’s are also arm, gen are 64 bits).
Would be funny if the MPC community provides us with new plugins :slight_smile:
The akai plugins are Linux shared library following the VST 2.4 binary interface; acording to the github docs on:
But lets first see what happen by their community. I quickly found this site:
Regards Paul
The ecosystem is new and mostly made with an AI coding agent. It is doable but it seems than existing plugins could be built directly as CLAP, which would avoid yet another format :slight_smile:
Hi @PLJ :slight_smile:,
As you may have already inferred, from the multiple times this somewhat hot subject has been raised in this forum, the main developers here aren’t keen to introduce VST support in Zynthianland.
There are various reasons for that, concerning the greater system footprint, lesser dependability within the project’s framework, increased coding and maintenance requirements and the standard itself not being open-source, but still a company trademark in 2026.
So, although the proposal has been advanced in the past, I wouldn’t hold my breath for any kind of VST support to be added anytime soon.
Best regards :rainbow:
If supporting other formats beyond LV2 wouldn’t cost safety or scalability and would add quality plugins, why not?
Because VST2 plugins can"t be fully integrated. They lack some important features we need, like parameter groups, param designation, ticks and labels, and specially, string parameters. VST2 was not designed to allow FULL separation of DSP and UI.
While the first “missing features” could be added as external plugin metadata (a ttl?). The lacking of string parameters is difficult to solve and it’s a serious stopper. Without string parameters we can"t load files, (samples, IRs, neural models, etc.) from the zynthian UI. VST2, CLAP or AU plugins that need loading files depend of the native GUI linked to the DSP. Full DSP/GUI separation is not possible without string parameters. This is only possible for a fraction of them. AFAIK, LV2 is the only format that allows total separation of DSP and UI for all plugins.
We could integrate other plugin formats, but the integration will always be hard-limited because of this lack: string parameters
This has been already discussed in other threads. Perhaps someone could link It here. i couldn’t find It
Maybe it would be a good compromise if there was vst and/or clap supported by external metadata, excluding plugins needing text parameters. I mean, in lv2 we need to group parameter groups manually anyway because few devs do it themselves, and there were plenty of new plugins to add.
If we have VST support, but not ones that require strings and not ones that aren’t available for arm64 and not ones that require an authorisation method that isn’t supported on our platform, etc. then we will be constantly getting questions, “why doesn’t my VST work?” which is a support burden we can ill afford.
There have been efforts to expand the plugin support but the cost is often deemed to outweigh the benefit. Each time someone asks for XXX plugin support, they don’t tend to also say what specific benefit it provides, or if they do, it is often to run a plugin that isn’t supported or there is an equivalent already available. (We have about 1000 plugins available.)
Good point. Since no one is offering arm64 binaries we would be limited anyway to open source vst/clap plugins to self compile for arm64. And then with the mighty new toys everybody is talking about it might be possible to compile these as lv2 then.
