MiniDexed is really fantastic.
Would it be possible to integrate in Zynthian?
Dexed is already in the default lv2 plugins. You might need to enable it in the webconf.
Mini Dexed runs 8 Dexed in the same time
I think MiniDexed runs in bare metal, it may be difficult to run inside the Zynthian’s Linux ![]()
You ca run 8 instances of dexed plugin in zynthian ![]()
You can also run seven or nine instances ![]()
For the sake of clarity, there’s not a lot of point trying to get minidexed running in Zynthian as the synth engine shares the exact same codebase as the Dexed lv2 plugin. It’s like asking to put the engine from a Ford GT in a Ford Lincoln Blackwood
