Experiencing the same problem, running the latest version.
This comes up in the log:
Jul 27 01:58:48 zynthian startx[12952]: A dependency job for mod-ui.service failed. See 'journalctl -xe' for details.
Jul 27 01:58:48 zynthian startx[12952]: ERROR:zynthian_gui.zyncoder_read: Command 'systemctl start mod-ui' returned non-zero exit status 1.
Jul 27 01:58:48 zynthian startx[12952]: Traceback (most recent call last):
Jul 27 01:58:48 zynthian startx[12952]: File "./zynthian_gui.py", line 1252, in zyncoder_read
Jul 27 01:58:48 zynthian startx[12952]: self.zynswitch_defered_exec()
Jul 27 01:58:48 zynthian startx[12952]: File "./zynthian_gui.py", line 1201, in zynswitch_defered_exec
Jul 27 01:58:48 zynthian startx[12952]: self.zynswitch_short(event[1])
Jul 27 01:58:48 zynthian startx[12952]: File "./zynthian_gui.py", line 1147, in zynswitch_short
Jul 27 01:58:48 zynthian startx[12952]: self.screens[self.modal_screen].switch_select('S')
Jul 27 01:58:48 zynthian startx[12952]: File "/home/pi/zynthian-ui/zyngui/zynthian_gui_selector.py", line 251, in switch_select
Jul 27 01:58:48 zynthian startx[12952]: self.click_listbox(None, t)
Jul 27 01:58:48 zynthian startx[12952]: File "/home/pi/zynthian-ui/zyngui/zynthian_gui_selector.py", line 247, in click_listbox
Jul 27 01:58:48 zynthian startx[12952]: self.select_action(self.index, t)
Jul 27 01:58:48 zynthian startx[12952]: File "/home/pi/zynthian-ui/zyngui/zynthian_gui_engine.py", line 169, in select_action
Jul 27 01:58:48 zynthian startx[12952]: self.zyngui.screens['layer'].add_layer_engine(self.list_data[i][0], self.midi_chan)
Jul 27 01:58:48 zynthian startx[12952]: File "/home/pi/zynthian-ui/zyngui/zynthian_gui_layer.py", line 281, in add_layer_engine
Jul 27 01:58:48 zynthian startx[12952]: self.add_layer_midich(None)
Jul 27 01:58:48 zynthian startx[12952]: File "/home/pi/zynthian-ui/zyngui/zynthian_gui_layer.py", line 303, in add_layer_midich
Jul 27 01:58:48 zynthian startx[12952]: zyngine = self.zyngui.screens['engine'].start_engine(self.add_layer_eng)
Jul 27 01:58:48 zynthian startx[12952]: File "/home/pi/zynthian-ui/zyngui/zynthian_gui_engine.py", line 180, in start_engine
Jul 27 01:58:48 zynthian startx[12952]: self.zyngines[eng]=zynthian_engine_class(self.zyngui)
Jul 27 01:58:48 zynthian startx[12952]: File "/home/pi/zynthian-ui/zyngine/zynthian_engine_modui.py", line 85, in __init__
Jul 27 01:58:48 zynthian startx[12952]: self.start()
Jul 27 01:58:48 zynthian startx[12952]: File "/home/pi/zynthian-ui/zyngine/zynthian_engine_modui.py", line 101, in start
Jul 27 01:58:48 zynthian startx[12952]: check_output(("systemctl start mod-ui"),shell=True)
Jul 27 01:58:48 zynthian startx[12952]: File "/usr/lib/python3.7/subprocess.py", line 395, in check_output
Jul 27 01:58:48 zynthian startx[12952]: **kwargs).stdout
Jul 27 01:58:48 zynthian startx[12952]: File "/usr/lib/python3.7/subprocess.py", line 487, in run
Jul 27 01:58:48 zynthian startx[12952]: output=stdout, stderr=stderr)
Jul 27 01:58:48 zynthian startx[12952]: subprocess.CalledProcessError: Command 'systemctl start mod-ui' returned non-zero exit status 1.
And running journalctx -xe reveals:
Jul 27 01:43:46 zynthian systemd[1]: Starting MOD-HOST: LV2 plugin server...
-- Subject: A start job for unit mod-host.service has begun execution
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- A start job for unit mod-host.service has begun execution.
-- The job identifier is 1298.
Jul 27 01:43:46 zynthian jackd[472]: error: PROTOCOL_MAX_COMMANDS reached (reconfigure it)
Jul 27 01:43:46 zynthian jackd[472]: No jack_get_descriptor entry-point for mod-monitor
Jul 27 01:43:46 zynthian jack_load[8643]: mod-monitor is running.
Jul 27 01:43:46 zynthian jack_load[8643]: client name = mod-monitor
Jul 27 01:43:47 zynthian jackd[472]: No jack_get_descriptor entry-point for mod-host
Jul 27 01:43:47 zynthian jackd[472]: failed to open mod-monitor client
Jul 27 01:43:47 zynthian jack_load[8647]: could not load mod-host, intclient = 0 status = 0x 1
Jul 27 01:43:47 zynthian systemd[1]: mod-host.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
-- Subject: Unit process exited
-- An ExecStart= process belonging to unit mod-host.service has exited.
-- The process' exit code is 'exited' and its exit status is 2.
Jul 27 01:43:47 zynthian jack_unload[8650]: mod-monitor unloaded.
Jul 27 01:43:47 zynthian systemd[1]: mod-host.service: Failed with result 'exit-code'.
-- Subject: Unit failed
-- The unit mod-host.service has entered the 'failed' state with result 'exit-code'.
Jul 27 01:43:47 zynthian systemd[1]: Failed to start MOD-HOST: LV2 plugin server.
-- Subject: A start job for unit mod-host.service has failed
-- A start job for unit mod-host.service has finished with a failure.
-- The job identifier is 1298 and the job result is failed.
Jul 27 01:43:47 zynthian systemd[1]: Dependency failed for MOD-UI.
-- Subject: A start job for unit mod-ui.service has failed
-- A start job for unit mod-ui.service has finished with a failure.
-- The job identifier is 1297 and the job result is dependency.
Jul 27 01:43:47 zynthian systemd[1]: mod-ui.service: Job mod-ui.service/start failed with result 'dependency'.
