Mod-ui problems - some FXs not working
hello! first time posting here. I’m building a DIY Zynthian and playing around with the mod-ui. I’m trying to replicate this pedalboard but none of the Aurelien AMS FXs works. when I try to drag any of them to the pedalboard the interface automatically disconnects and I need to reset the chain
is there a way to fix this? I haven’t looked into chain-routing in Zynthian yet. I don’t know if this routing complexity is possible outside of mod-ui
thanks in advance
That’s a fair old floor of pedals!
Have you added the appropriate components in the webconf engines section…?
I don’t know, but I suspect these will not auto loaded by MOD.
The zynthian chain routing in regard to swallowing MOD-UI patches whole is as you refer in it’s infancy, but it might be fun to see how far we could get. . .
Hi @abustos! Welcome to the family.
Plugins do not need to be enabled in webconf for them to be available in mod-ui. They are handled separately by zynthian/mod.
The first issue I hit with porting this board to native zynthian chains is that I can’t find TinyGain in zynthian. Next, the blue pedal with OPENAV on it does not appear in the list of plugins below the board.
Zynthian does not currently natively route CV so that part of the patch isn’t easily implemented.
Well that told me.
I’ve loaded up the various AMS devices into engines within the zynth, but the oscillator group does not appear as an available category. So can’t add the VCO3.
Which is sort of the same conclusion.
Welcome by the way . . .
so there is no chance it will work in mod-ui?
No. The audio modules should load it’s the mod ui concept of a control voltage that isn’t implemented so this is what is preventing those loading…
