If I am running a mod-ui and try to toggle through zynthian’s setup list to adjust different parameters, the cursor is jumping back to the first line on specific lines.
When I stop the mod-ui service (hence stopping the mod-ui server) then everything works fine in zynthian’s box interface (I can adjust all the parameters).
There seems to be some interference between the controller knob events of zynthian and the web server of the mod-ui.
@jofemodo Indeed. That’s quite the list. I’m happy to help with MOD-UI for now. And for the little bug, let me know if you need anything else. Happy to give back.
@gitnob Great! And funny we stumbled upon the same issue at the same time.
I can’t see any problem … well, perhaps i don’t understad the problem because your description is “too short” … jeje! Perhaps you could give me a more detailed description of the problem so i can reproduce the problem …
It’s easy to explain. Use mod-ui as a layer in zynthian and try to toggle through the parameter settings of the lv2-plugins of a specific pedalboard.
This did not work because you could not reach the lower parameter settings because the selected line was set to line #1 of the parameter list every now and then.
@jwoillez’s patch helped and solved the issue (and obviously also his problem).
@jofemodo, which bugfix did you commit, to compare…
