I’m wondering if I am using zynthian correctly. What i’ve wanted to do for a while is to set up 4 or 5 layers which are all triggered from one midi channel. I want to play my song on the piano and hear 5 different sounds all triggered at once. E.g. piano, ep, pad1, pad2, bass. Then mix volumes with the mixer etc. I tried to switch to multi timbral mode? Is that a good idea?
In order to get the sounds all playing I seem to need to use midi clone… but then I lose the mix when I use the mixer because it switches to soloing just that sound, or in multi timbral mode I get no sound because I’m assuming each layer is pegged to a midi channel.
If I can get a multi layer set up like that to work, my next dream is to be able to swap a snapshot quickly, how would one do that?
Results so far, I’m enjoying…
