And now, yes!! My eyes are more open after holidays …
I’ve commited the fix that solve the problem for HifiBerry soundcards. People using other soundcards and having this problem should report the device name in this thread, so we can extend the solutions for all supported soundcards. Simply send the output of this command:
aplay -L
Ahh! Important! After updating your zynthian, you should re-configure your soundcard from webconf and reboot your zynthian. For doing that, first select “dummy” soundcard and then your soundcard. If you are using the “kit” configuration, then select your kit, save and reboot.
for the audio injector machine (zynthian-alm)
aplay -l
card 0: audioinjectorpi [audioinjector-pi-soundcard], device 0: AudioInjector audio wm8731-hifi-0
Subdevices: 0/1
Subdevice #0: subdevice #0
On zynthian-amp2(7" screen hifi berry Amp2 card)
A power off restart with two MIDI keyboards connected via USB,
still brings up a crashed GUI & no sound but crucially webconf does appear.
You can reboot from the webconf, which kicks a reboot which comes up with the zynthian Error screen showing ip:0 … briefly. This then clears to normal white boot screen and then into GUI with sound !! on both keyboards . . .!!
