Names of snapshots and snapshot folders
Snapshot folders:
it is necessary to have a number before folder name (i.e. 100-templates) or not (i.e. templates)?
If I choose the 2nd one, folder disappear in snapshot folder list
Snapshot names:
it is necessary to have a number before snapshot name (i.e. 100-piano) or not (i.e. piano)?
Both seem work
The number is the program name. When you enable Master Channel you can use Program Change to load snapshots.
The UI “hides” the numbers and you only see the snapshot name.
Yeah, it’s confusing, until you remember: “MIDI” – it knows numbers, not names.
Snapshot folders are MIDI “banks.”
Snapshots are MIDI “programs.”
Things may be a bit different when using ZS3s selectable by MIDI program. I haven’t gotten to that, but soon will.
I don’t like the numeric prefixes. They look untidy and often cause conflict warnings. I wonder if we might consider a mapping mechanism so we don’t need to encode the number on the filename which makes it more portable. Maybe someone wants to add a feature request.
Never embed data in display strings.
They are different things.
If you try it I will be forced to tell the history of Video tape box labels from the dark ages of the 1990’s when synths were polyphonic and Denmark Street was close.
